Rear Shelf........
Could always remove the passenger seats as well and save even more weight!
Its a one-seater, honest..
:rofl:
I shouldn't really as I have a 22 mile each way trip to work now! Taking a bit of a risk! :rolleyes:
:rofl:
Now theres an idea for the national meet! :D
Depends if you're risk-adverse, or risk-loving? My commute is a 52 mile round trip, most at serious speed, so would never risk not having a spare to fall back on. Removing the rear seats is an option....? :D
what about removing the doors aswell :D
What about using the thinner MDF,and using cut-off's to make supporting ribs underneath ?
some of us need to use the boot space - so cannot afford to fill it with Sub's -- so some nice large rear speakers fitted to a nice sturdy shelf should be a good compromise - shouldn't it ?
or line the underside of the std shelf with mdf and screw the spks in from below.. its the material the spks are mounted to that matters :D
Hmm -- would you need to cut any holes to allow full transmission of sound - or will it travel anyway -- if it works would be grate - saves trying to make a shelf match,and yet still gives stealth install -- as long as its strong enough to take the extra weight.
If you want to do it that way , cut a sheet of MDF to match the shelf.
Cut speaker holes in both the MDF and shelf.
Screw the MDF to the bottom of the shelf , then cover the shelf with fabric/carpet to suit.
Attach speakers to bottom of MDF.
You will lose much of the sound if you don't have holes in the shelf.
:rofl: Now why did I get a Frank Spencer image reading that ..... :rofl:
OOh Frank! :rofl:
