Mk3 Mfsw in a Mk2 FL
Where did you find a steering wheel without paddles?
I only bought as it was slight cheaper than the non-paddle one!
They can be removed easily but then there would gapd in the back.
  • Replies 58
  • Views 13.2k
  • after a long wait all in and working nicely     http://www.youtube.com/watch?v=WCuZhOOl-IE   Not a cheap one, but does look good
  • Sounds interesting but...pics or it didn't happen :p
  • well it did happen, and will happen again when i can figure out how to get it to work.   i took it off as it didn't work to my satisfaction
I currently have the MFSW in my manual VRS, which is working perfectly. Will the flat bottom, non paddled, VRS wheel be a straight swap, and would it require any additional coding?
It depends if its pre-fl or FL:
Pre-FL - you may need to change the steering wheel controllor to highline one and need to get the Superb FL MFSW buttons (5E0919719 F) - coding will be required.
FL - You will need to change the buttons but not sure on the coding.
its a FL
Will i be able to reuse existing airbag?
its a FL
Is it the same shape?
doesn't look like it is.
Maybe just too expensive to do this circa £500
You wont be far off that
Edited by Awesam
/w1pohf.jpg
Is your car pre-fl? If it is and y you had a fl maxidot fited do you have any problems with immobilizer?
Edited by egres
I want to get fl-maxidot cluster to my pre-fl Octy because of the communication between rns510 and MFSW from superb 2fl.
Edited by egres
Yes it is a Pre-FL.  I had to get a FL maxidot if i wanted MFSW otherwise I dont know of any Pre-FL with a MFSW.
Eddie coded the cluster and provide new transponders for the remotes.
Im really pleased with it, it has updated/modernised the dash and the steering wheel feels great!
