What songs do you class as Epic? (eg for testing a hi-fi or for fun)
fabdavrav
Recommended Posts
I sat in it with Massive Attacks Blue Lines on at 500 db and after a while I couldn't breathe and thought I was ill.
He explained that his epic bass actually interfered with your diaphragm and ability to breathe and would ultimately kill you!
500db
That's like gonna kill everyone and make the planet implode.
I had about 134 which if I pinched my nose and breathed in it would stay shut.
Copped a noise pollution warning for that too lol
Link to comment
Share on other sites
Cranberries - Dreams
Sting - Englishman in New York
Dire Straights - Brothers in Arms, The Man's too strong, Once Upon A Time In The West, (money for nothing too for a goes to 11 test)
Pendulem - Voodoo People (Their version really tests the bottom end)
Queen - Too Much Love Will Kill You
Freddie - Living on my own
Corner Shop / Norman Cook Remix - Brimfull of Asha
Suede - Beautiful ones
Link to comment
500db
Did chuckle at the 500db remark as that would've been interesting! 134db in the late eighties was respectable to be honest and more than enough to burst your ear drums if exposed long enough. Did you use multiple batteries and the typical split charging system to attain that level?  We would always wear ear defenders when setting up and more than often leave the SPL meter attached to the steering wheel for the final pressure level test. Believe they exceeded the 180db mark in the early 2000's but lost interest after that. Preferred the very subjective sound quality testing as that was at a more manageable level and revealed the true capability of the system.
Also had a few sound effect cd/tapes which had snippets of F1 racing/harrier jump jet taking off and daft things like the Robocop voice which raised an eyebrow when used every now and again. Fun times!
Link to comment
Guys,  500 db was artistic license intended to amuse.
If you do the maths you would need 100,000,000,000,000,000,000,000,000,000,000,000,000 watts per sqm to achieve it.
You would only achieve this if you had an amplifier with a volume control that went up to 11.
At that point the ear defenders I was wearing might prove inadequate.
If you wanted to survive as well, a ship with warp drive capability, a good shield, and the ability to create worm holes to other universes might also be useful.
  • Like 2
Link to comment
There is a huge difference between testing HiFi and noise generating equipment. Having stood within 30 yards of a Harrier doing a vertical take off, and considerably closer to Top Fuel cars at full chat, the experience is pretty visceral. If we are talking big numbers, I have encountered a 192KW amplifier in my professional life.
Link to comment
From a personal perspective I preferred to use very efficient speakers and amplifier capable of driving into reactive loads nearing 1 ohm. Fewer boxes interfering with the signal path brought its rewards :)
1 track I got fed up of hearing but was a good test was the then newly released Madonna's Vogue 12" mix. The Cerwin Vega demo vehicle (think it was called Earthquake) used to blast it out regularly at 140+ which was enough for most!
Link to comment
I tend to go with high efficiency easy load speakers and low power, low feedback design amplifiers. The 192KW amp was three channel, 192KW RMS per channel working between 0.2 and 22,000 Hz. The drive units used water cooled copper pipe as windings and could be coupled to a load of up to two tonnes and move that load faithfully to the signal. Never heard music through it, but many of the test programmes had mostly audible spectrum signal. Far from HiFi.
Link to comment
Mine was early 90's, lots of Alpine v12's when they first came out and some JBL12's, no split charge, had the bits but never got that far, Dynamat was my secret weapon, and well designed ported box.
If I'm honest 134 was a peak I got at a local comp, I think usual was around 130 which as you know is still loud enough for most old ladies to **** a brick when you drive past.
I used to use those bass mechanic CD's with sine sweeps, I could set off car alarms parked on the road side, but multi storeys were great set off about 10 car at time lol
Oh to be young again ......Pardon, did somebody say something ??!!
Just checking lol
Link to comment
Exposure to high SPLs in the order of 130db will result in serious hearing loss, so HiFi could become academic. I have been in a 130db white noise working environment and without ear defenders the pain would be unendurable.
Link to comment
It is possible I got my levels wrong there then lol, It was the early 90's after all. All a bit of a blur.
There again I do have a touch of tinnitus and can't hear much if there is any sort of background noise, so there was a little damage.
Maybe it was 120 peaking at 124, I know it peaked on certain notes at 4db higher.
All the cash I threw at it including security, you know what I don't even have a photo of it all. One of the amps is still going strong in my mates car though
Link to comment
i call bs on 500 decibels, you would be permanently deaf at that sound pressure level.. i work with massive public address and concert sound systems as part of my job, around 125 to 130 decibels is the pain threshold, at around 140db your ears will start to bleed...
  • Like 1
Link to comment
That has already been established mon ami.
Getting back to the OP.
Music programme that impresses?  :)
Link to comment
Now 500W of bass in an AX GTI is engough to crack the glassfibre roof/boot!  Seen a guy at college showing off his new sony 6 disk changer system, and crack!
Link to comment
quite right, there is a band called mad season with an album called above.. I think it was the geezer from Alice in chains and somebody else who escapes me now... Anyway, there are a few songs on there which are great for setting up graphic Eq's properly, there is a good mix of sub bass, heavily gated percussion, a huge dynamic range, and a nice 2khz-4khz vocal and guitar track which is the band the human ear is most sensitive to, really well mixed down those were at the mastering stage...
Most modern manufactured rubbish is has too much compression applied because it's designed to be listened to through iPod earphones, so it's hard to find anything with a descend aural content to set up or test a hifi properly.
  • Like 1
Link to comment
Evanescense - Bring me to life - hell of a bass rumble on the intro.
Pachelbel's Canon
Leo Delibes - Flower Duet
Erm... Anything classical with low strings. Shows how yer bass has holes in it.
Never say die - Black Sabbath - overtracked/produced maybe but more complex than the average.
G&R - Anything from Appetite...
If you're trying any of this with MP3s, go sit on the naughty step.
Link to comment
Just been listening to DMX "the Great Depression"..........
....bloody hell it's got some deep bass...........mind you my new hi-fi shows it up much better & clearer............ :giggle:
Link to comment
Don't the stereo competitions just use fixed tones now rather than music?
Those sound offs, yes but they are just interested in noise not the musical quality.
Link to comment
Dire Straights - Money for nothing has been my car stereo set up track since I had my first cat at 17, now 31 and it will be the first thing played in the new car when arrives to dial that system in without fail!
Other car music would be bit of ZZ Top - Afterburner album, Dire Straights - Romeo and Juliet album, Nickelback, Guns 'n' Roses, Gary Moore etc etc, rock anything basically if you get the drift
  • Like 1
Link to comment
  • 3 months later...
Just got a new album..........
Magnificat singing the Lamentations, Mass & Motets written Thomas Tallis in around 1560's. recorded by Linn records.
All I can say is set your hi-fi up properly & just listen with no distractions to "Spem in alium"
:o  :o .........................
  • Like 1
Link to comment
Radiohead - The Bends
Holst- Mars or Jupiter
Underworld- Rez or Luetin
Members of Mayday- 10 in 01
Daft Punk- Alive (97)
Mojave 3- Give What You Take
Pink Floyd- Learning to Fly
Flaming Lips- The Gash
Edited by sparks03
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
