Do factory Audi wheels fit the vrs with out adapters?
So just wondering if factory RS4, RS6, RS/S5 wheels fir without adapters? Not a huge fan of reps and think factory wheels are the way to go unless I'm spending loads on lightweight wheels! I'm not up on widths/PCD's and offsets!
Gotta watch audis
They swapped to 5x112 early on mate
To bolt on u want 5x100 around et35
8j wide is easy
When u go 8.5 or more then spacers can get involved
Hub size 57.1
Thats great, thanks for the info!
Got a set of TT wheels on my Octy right now.
Like Lloyd said, 5x100 and 57.1mm.
Mine seem to sit a bit further out than the standard spiders, even with no spacers.
Had some S3 MK1 alloys on mine 7.5X17 ET32, filled the arches nicely, but they heavy old lumps 13.2kg compared to Spiders 9.3kg, i noticed the difference. :thumbdown:
  • 6 years later...
Hi Does anyone know if a 13 plate audi a3 wheels would fit on my 15 plate skoda octavia estate?Thank you
Go on one of the alloy wheel sellers websites and put both vehicles into the checker, they show the wheels that fit and the spec for the wheels for each vehicle.
www.alloywheels.com allows you to check by make and model if you don't have the reg.
Thank you.I went on the website you said, can't find the checker where I could compare.Do you have a link?
Put your car in. It shows the wheels that fit, click on one of the actual wheels and note the spec. Then do it again for the Audi. There are better sites that show the full spec of the wheels, someone posted a link to new wheels on an Octavia about a week or so ago that included the link.
The website was for wheelbase   https://www.wheelbasealloys.com/?msclkid=dae0a451c32f19a77a7ffb29aebc5067
Edited by VRS_White_Hatch
