Large Speedo Display
Recommended Posts
My Superb is 4 years old, but here is some info that might be relevant ;-
To change speed display to LARGE MPH, lights (Fogs not Bi-zenons etc) see
http://www.briskoda.net/forums/topic/217595-my-ex-candy-white-yeti/#entry2560747
- 09-Cent. Elect. - Coding 07 - Long Coding Helper - then under Byte 17, bit 3 -
Xenon Headlights with Shutter without additional High Beam installed
To change the "maxi-dot" display from km/h to mph? If so you need someone local with VCDS, it’s well documented here what you
need to do.  http://www.briskoda.net/forums/topic/229766-vcds-adaptations-how-do-i/
Link to comment
Share on other sites
As far as I am aware, the coding of the cluster to get the large MPH display no longer works on the facelift version, the cluster no longer accepts the change in coding. I don't believe an alternative way has yet been found.
Link to comment
From what I have read, you cannot alter the country coding from UK, though I stand to be corrected.
My Octavia FL Vrs has been changed to Australian Mode to get the Large Speedo. I would have thought that all country coding would be available  on all the range of models. Obviously not.........
Mike Holroyd might know, PM him  If mike doesn't know no one will TBH
Link to comment
Yeah there are several threads about it on here but I don't think anybody has reported success with a FL Superb yet.
Edited by EyghonUK
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
