Worn engine mount?
Evening all,
I've noticed this for a while now, but when my Vrs is idling on a downward slope (engine downhill) there is a occasional rumble/vibration noise. The noise is less pronounced when clutch is depressed.
Looking online a worn engine mount may be a cause, what do we think?
Matt
I hate doing this, but.....bump
What's it like when you're pulling away?
My mate had a 206 GTI that's engine mounts were so worn, when you pulled away it felt like the engine was trying to jump through the dash
Lower one is a cheap and easy diy job only 4 bolts so might as well change that for the cost, the powerflex diesel one is good. Fitted it other week.
But thought if there is a change with clutch depressed it points towards flywheel been on its way out, if you are still running a dual mass. But don't.know with it only happening downhill.
Note, I am no mechanic just a reader of the forum.
Both lower "dogbone" gearbox mount + upper gearbox mounts are common faults.. wears through rubber n metal on metal vibrates.
