Advice on N249 and N112 removal
Removing the N249 is easy buddy.
But as you are not removing SAI and N112 then no point removing N249 , just bypass it and leave it in place so it is all still connected and this means you won't get a engine check cell or to worry about pipe connections under the metal bracket.
here is a Guide I just found searching the net in less than a minute
http://www.seatcupra.net/forums/showthread.php?t=348572
And the dipstick tube is a common part that breaks as the plastic get hard and brittle due to engine heat over time
Cheap to replace
  • 4 weeks later...
So, did this. Leaving the n249 and n112 wired so not mesaing with resisters etc. Nearly 2 weeks later Eml pops up with p0411 sai incorrect air flow!
Is this because ive bypassed the n112 or is there actually likely to be a fault with the sai?
Thanks in advance
Sent from my GT-I9300 using Tapatalk
