Hello
hello , newbie here,
well been a member for a while but never posted,so here goes, please dont bite my head off for having a golf, but i have built a mk2 golf syncro with 20vt quaife 6spd most of it done by jabba, knowing most of you love jabba, some of you may have seen the car sat there for over a year a dark green golf with no door handles and mike swearing about it alot, my probelm is i have fitted a haldex diff and got it working but i need some info on the skoda octavia 4x4 20vt gearbox and transfer box, is the code the same as the syncro i.e 02c? wot is the part no.?wot are the ratios of the transfer box , is the transfer box the same as the TT or mk2 syncro with TT ratios and are the oil ways the same as mk2 syncro?
many thanks stephen
Hi nutter4X4. Welcome to Briskoda.
I can help with the gearbox code for the 2002 1.8T 4X4 - namely FEX. The part number is 02C 300 011 BL. If you post the VW part descriptions and part numbers you want to compare, it should be possible to check ETKA to see if the Skoda part numbers are the same.
ta very much , do you know the ratios of the transfer box?
is there any breakers that deal with the lastest octavias??
  • Administrators
Not sure if it helps, but www.awesome-gti.com had a TT 5spd gearbox for sale...might have other bits aswell.
cheers, but thats a 02m box and not 02c, the oil ways are in a different place on the transfer box for wot i need
hello, i need some more info of someones ekta , if you can ta , could you give as info on the gearbox EAG code may be some pics too?,i have found one just making sure its wot i need,
i am trying to get my car running properly , its been along time now almost 3 yrs start to finish, soon as the gearbox is sorted i can get my self booked in to jabba
many thanks
nutter,
can't help you with your query but i can welcome you to briskoda!!!
Nutter, forgot to bring ETKA to work this morning, PM me your e-mail address and I'll send through some stuff this evening.
Work????? You told me you didn't work!;)
so why would you take it to work? do you work for skoda or do you do some skoda parts business from work ??
he takes it to work cos he uses it like others of us use porn;)
Jon does as much work as me:cheers:
welcome Nutter4x4 by the way
here it is i wondered where the thread had gone !!
so who`s running the most power and torque and wot spec have you got ?
1MB mail on its way :D
thanks very much peeps its just confirmed its wot i need so i can go get me new gearbox and have my car back on the road
