Side Lights not working
My side lights aren't working. Tried changing the fuse, still no go.
What should I do? How do I check if the bulbs are gone?
Has your car got drl's as they are the side lights.
Checking/changing side light bulbs is a headlight out job. Simple case of removing a plastic nut at the back of the headlight and then pulling a hook on the inside of the headlight beside the grille, towards the centre of the car and the headlight should pull forward. Just be carefull when removing the headlight as the loom for the bulbs can be short.
Nope. No DRL's
(VRS only) To this day I am baffled by this. No lights on = bright DRLS. Sidelights = dimmed DRLS + rear lights. Oddness. What to choose? Never use the sidelights setting as a result.
  • 8 years later...
Just bought a 2011 VRS and am baffled by this also, I’m guessing the bulbs in the side lights at for continuity sake then?
