curiosity with idle jet - primary
regards
I have a curiosity with idle jet - primary.
to lay a finger on idle jet - primary, some engine speeds
Is it normal?
my car is 2000 skoda felicia glx 1.3 carb
idling unstable by placing your finger on idle jet - primary, stabilizes the idle
Ricardo, you had already the answer to your problem.
this new topic will not bring you a miracle answer.
there is a vacuum leak below carburettor.
it's that gasket not sealing properly.
not to mention the mounting method with 3 bolts which sucks big time.
ask anyone, vacuum leaks produce weird effects: rough idle, hunting idle, no start, revving and stall, etc, etc.
so follow exactly our numerous and detailed advice and FIX THAT LEAK!
greeting
thanks for quick response
truth is frustrating not being able to find a vacuum leak ...
change this:
Motor oil
brake bands
caliber Valves
take the metal base that comes with manufacturing defect, leading to a rectified around
buy all new hoses
Buy All new vacuum
buy gasoline resistant silicon and high temperature
failure was  idle unstable ,no solution
missing change:
spark plug wires
and spark plug
followed several post to the letter, you can not solve, so I opened this post
solution:
to buy a cardboard seals (waterproof, gas and oil) 4 mm thick as last option follow this post: http://www.briskoda.net/forums/topic/302512-carburetor-possessed-evil-skoda -felicia-glx-2000 / to the letter all ready solved .... thanks
thanks
dohnjoe is the best
Saludo
gracias por su rapida  respuesta
la verdad es frustrante  no poder encontrar una fuga de vacio...
cambie en busca del fallo:
Aceite del motor
bandas frenos
calibre Las Válvulas
lleve la base de de metales  que viene con defecto de fabrica, lleve a un torno a rectificaran
compre todas Las mangueras  nuevas
compre Todos Los vacuum nuevos
compre silicon Resistente a la gasolina y las altas temperatura
no encontraba el fallo ralenti inestable, no solucion
faltaba cambiar :
cables de bujia
y las bujia
segui varios post al pie de la letra, no puede resolver,  por esto abri este post
solucion :
compre un carton para hacer juntas (resistente al agua,gas y oil) de 4 mm de espesos como ultima opcion segui este post: http://www.briskoda.net/forums/topic/302512-carburetor-possessed-evil-skoda-felicia-glx-2000/  al pie de la letra .... listo todo solucionado  gracias
gracias
dohnjoe eres los maximo
