mk2 vrs tfsi
So I tried to be responsible and grown up when I bought the zafira, but I hated everything about it definitely the worst car I've owned. So went for something practical yet fun, which led me to this I picked up two weeks ago..
Plans are colour code grill, lower, cat back, tints and enjoy until I can afford more substantial mods.
My second son is due in June so no real progress till after then. But doing as much as I can as soon as I can.
Edited by VrsStebuzz
  • Replies 106
  • Views 15.7k
  • Well me and my little helper set about fitting the splitter... Absolutely made up with how it looks.
  • New tyres arrived today so just need time to get them fitted and I can say good riddance to the spare wheels. I went for Goodyear eagle f1 assymetric 2. Found an eBay code on uk hot deals and got ยฃ50
  • Postman came today these arrived first. Gutted the sidelights arse too big to fit in the hole. But the number plate lights... Happy with those. Then the better parcel turned up. So of course
Looks like a good base to start with. ย Look forward to your progress.ย
Congrats on your VRS, is it a diesel? Look forward to your mods :)
No it's a TFSI like in the thread title.
  • 4 weeks later...
Gave the car a good clean today and also did this
Was going to wrap it in black vinyl I've got lying around, but after 're-fitting the grill I felt it was too much black so will be colourcoding it instead.
Will pick up some wire wool too to try and tidy the exhaust as it's not looking it's best.
All primered up early this morning, just applying coats of colour now
In between coats I also removed the "Octavia" badging.
The TFSI responds really well to engine mods, my TFSI is at stage 2+ and Porsche brake setup.
ย
If you are in the area sometime, you're welcome to come and try it ;)
ย
Sorting the looks out primarily but will be looking at engine mods in the future. Telfords a bit of a trek for me, used to be down there frequently when I did work for severn Trent water but never have a need to go that way nowadays
All the paint coats on and dry, leaving overnight and will laquer after work tomorrow.
Need to order new style badges too.
What prep before primer, finish look's really good even before laquer is applied. Wanting to do this mod to my fl Octy black magic paint.
Gave it a good wash with fairy liquid and hot water to remove all grease and dirt, keyed the surface with 2500 grit and 're washed. Then just apply thin coats worst thing you can do is get carried away and start smothering it you just have to be patient.
I'm made up with it so far, it's a well worthwhile cheap mod that makes a huge difference
Let me guess... remap, 19", drop? :)
Possibly a map in future but not soon, I rarely push it to the limit as it is so no need and I'd rather get the cosmetics as I want them first.
Wouldn't go near 19" as they would just destroy the ride, 18" are more than adequate on these.
I'm looking at springs to improve the handling and take away that horrendous arch gap, but not 'slamming' I still need it to be usable and again don't want to destroy the ride as I'll have 2 young ones in the majority of the time.
Lacquered up, just need to polish it up and fit it. Also ordered some new badges as a bit of a gamble, will see of their good or crap when they arrive.
Grill is looking good. What paint are you using? Is it just aerosol cans?
Yeah just aerosol from my local paint shop, will run over it with some cutting compound tomorrow then polish and wax to give a shine.
Fitted the grill, not 100% happy after polishing it up a lot more potential to shine so going to wet sand it.
Badges have arrived and got a free bag of sweets :D now I've seen the quality of them I just need to order centre cap badges to match
Front badge fitted need to remove old rear badge at weekend.
Not progress as such but gave her a clean today and tried out my rotary polisher I dug out from back of garage, only did the bonnet as didn't have time to commit most of my day to it.
Before:
After:
Threw some poorboys blackhole on and some hd wax too. Need to order some more gear before I set out on the full car.
Ordering new wheels in the next few weeks as these have got the common corrosion issues and are leaking air in 3 of them, then full set of h&r 55mm springs and shocks that it's desperately crying out for.
Finally changed my number plate lights quick comparison pic.
Ordered my new wheels which should be with me by wednesday hopefully. Ordered wind deflectors too but messed up and ordered for an estate instead of saloon derrrrr
Nice looking motor fella :)
I was behind a 14 octavia earlier and it had the same rear plate as yours, claybank and manchesterskoda lol
Cheers mate, it's the irlam dealership just off the m60 eccles turn off.
Had some deliveries today,
Edition 35 reps, same dimensions as standard but et42 rather than 51.
Decided the gold badges don't work so got anthracite to match the wheels. (The bubbling isn't in the badge it's the protective film)
Pressed plates also arrived for when I finally put my reg on and hopefully wind deflectors will turn up tomorrow.
Hopefully have everything fitted at the weekend, providing the Mrs doesn't go into Labour!
Okay so I fitted the wind deflectors
But more importantly this happened...
These pics show the difference with et51 7.5j standard and now et42 8j
I'm absolutely made up with them, just need some lows next ;)
  2. Tap Permissions โ†’ Notifications.
