Angled bars in Boot
Hi, could someone please tell me the proper name for these bars in the boot which add rigidity to the chassis please.
How easy is it to remove them, is it literally 4 bolts each like it looks or are they deceiving?
I need some extra space in the boot on one trip so would like to remove them, they're quite obstructive!
I think we need a pic on this?
Poss strut brace.
Edited by ruffday
Poss strut brace.
thank god im not the only one...... sounds like something a previous owner has done?
similar to Bowders1's work in his boot with rear strut bracing.
The Vrs does come with 2 reinforcing struts, mounted on each side going from near the top of the rear suspension towers  and the other end bolting onto the floorpan. Just checked in ETKA they are called "Backrest" .
If your interested Part numbers are :- 1U6 - 803 - 329 Left side / 1U6 - 803 - 330 Right side
yeah was me..... :rofl:
If I recall it is 6 torx bolts each side. Quite straight forward to remove. Needs the seats down to get to the other torx bolts
Think they are called  luggage compartment braces, but skoda Etka has them as backrests????
Yes Mark thats what they are listed as, weird I know.
On a side note, getting ready to call on "the force" to, at long last put Superpro rear beam bushes in, they have been gathering dust in my office lol.
There you go
There you go
jesus you mean you are going to fit them this year.... :rofl:
Good luck trying to remove them, the bolts screw into captive nuts, only 2 of the bolts came out of mine, the rest just spins
Got rid of mine, made trips to the tip easier - Just unbolts with the correct size torx  - Haven't noticed any difference to the handling
Oiii you, no respect for the older generation :) , its ok for you young fit blokes, no aches and pains. Well thats my excuse anyway.
My joints now sound like they are sending out a SOS in morse code, thank god for asprins :( .
lol.. I am 46 dude.........I take ibuprofen more than i eat breakfast these days....
Ok guys...let's make a contest wich is older more pensionary or has bigger prostate
Sent from my LG-D605 using Tapatalk
i still managed to fit a 4 ft chest of drawers in my vrs even with the struts in place :P
Ive had a 2 seater sofa in mine with bars still in place
I aways thought these were factory fit and had images of the car splitting in 2 if i removed them lol
Sent from my GT-I9300 using Tapatalk
They are factory fit on a vRS, but it's just to stiffen up the rear end a little.
correct and they do a good job.
i would not run without them in my car
Please could someone post the Torx size.....4 mm is too small.....4.5 mm or maybe 5 mm?
Thank you.
I dont think they are torx bits tbh
They're like an 8mm spline or something like that - M8 or M10.  When I took some out out of the 6 bolts I think only 2 came out and the others span.  Very annoying!
Having asked.....today I managed to borrow an 8mm spline...this fits perfectly!
They're factory-fit parts, intended to assist with the overall balance, handling and body rigidity of our VRS's.
Why anyone would want to remove them, and potentially make their car worse, is beyond me???
Did you read the original post? It was to gain some extra space in the rear on one trip and then replace them after
I don't think they were fitted in the much slower Estate mk1 VRS's ............. Waits for Daves reply !
i need the nearside one if anyone has one they are throwing away!!!!!!
