clutch noise
Hey guys see if anyone can help I get this shudder/thud noise when just ticking over but goes away when clutch is pressed garage said they think its a barring but wont know till its apart ?
It drives fine do I just replace full flywheel and clutch?
Can you recommend a kit that dont cost the world for a 56plate 1.9 tdi.
all help and advice much appreciated.
I've just had to replace the clutch on my 09 vRS as the bearing had gone. My symptoms were a high pitched squeal when lightly on the clutch and was very noticeable when on hill starts etc.
I didn't replace the flywheel as they're meant to last about 100k on my model, so depends on your mileage?
It sounds like the thust bearing , gearbox out to replace the bearing. If the G/B is out I think you might as well change the clutch at the same time. I would only change the flywheel if it is scored or damaged in any way,
Thanks for the replys guys mileage is really high sitting at 227k so well used car had timing belt water pump done last week cause unsure if its been done safe than sorry
