Changed my gearbox oil today.
well mine was nearly that colour after the first  16K   (on a new box) smelled burnt    recon it's just too thin  --more than one way of skinning the emissions  /mileage cat
Interesting, it looks like something is wrong with your gearbox.
  • Replies 120
  • Views 25.8k
  • Part number & price for my car is on post 4,you will need to quote your reg no. of your car at your local dealer to get the correct oil.
  • Sadly its not my personal garage,its the workshop i work in for the MOD.
  • Part number was G052171A2 & it cost me £49.31 for 3 litres from my local dealer. i took out & put in approx 2.3 litres,hope this may be of use to anybody else wanting to do this job.
yep, that's why non-genuine manufacturers recommend 75W-90 for 6-gear gearbox.
AS I ALWAYS SAY - MANUFACTURERS ARE HERE TO MAKE MONEY NOT TO GIVE YOU A PRODUCT, WHICH LASTS FOREVER ;-)
Any one fancy changing my box fluid for some beer tokets in Yorkshire area :)
So has anyone used the :: Fuchs Titan Sintofluid FE75W in there Octavia VRS ? Mine has the MQ250 6spd gearbox in, it seems to meet the VW spec.
Get Liqui Moly 75W-90. It can handle rough driving but you will be disappointed until oil heats up to operating temperature. When cold, I can feel teeth in my gear box at first gear :-D
Fancy doing mine Mikey ? ;)
Sadly im not allowed to do any Civilian work in the workshop anymore due to insurance & security risks.......  :thumbdown:
Was joking mate,gonna do mine after xmas after seeing the state of your oil :)
I am still awaiting some one to do mine maybe a mini gear box oil meet hahahaha
Worth doing,if i still have my car at 100,000 miles then i will change it again,easy enough job to do,if your doing it at home you just need to get the car level on stands.
I would rather pay some one to get it right then me make a balls of it hahaha
Buy the oil yourself from the dealer & take it to the garage/mechanic you use & it will only take them 15-30 mins max on a ramp.
How annoying. Nothing made me think "I need to change my gearbox oil", but I figured that at 65k I should. Now, after having it done, it's stuff and notchy. I have to be more forceful and deliberate to change gears, particularly into second. Have they used the wrong oil, or put too much or little in?
was it done by a Skoda dealer? As non vag gear oil can also make the change notchy, especially when cold.
Nope local independent dealer. Should I be complaining or just deal with it?
I don't believe in lifetime fill either, I've changed my gearbox oil too religiously my fabia vrs has 102000 miles on it and I've just had to get the gearbox bearings replaced at a cost of £425. Saying that there's no other problems it selects fine so I'm happy hopefully it'll last another 100000 miles
Sounds like they just put non vag gear box oil, just get the vag oil yourself and ask if they can replace it. Had similar experience myself using non vag gearbox oil as it makes the change sit when cold, and it was all fine again with the proper stuff.
As ive said a few times in this topic now,just use the correct genuine oil otherwise you will get the problems your having,i had the same using non genuine oil when i changed the oil on my mk1 vrs a few years ago hence me using genuine oil this time on my mk2 vrs..How much has the garage charged you for the gearbox oil?
The invoice just says £60 to change it.
I paid nearly £50 just for the oil & that included a 10% discount for trade,id go back & ask them what gearbox oil they put in,sounds like they may have just put normal gear oil in. If thats £60 just for the labour to change it then they have robbed you,its a 15 minute job to replace it at the same time as a service on a ramp.
And if they have are they responsible for draining and refilling with the correct stuff or will I have to pay again?
If they are a half decent place then they should really change it for free,its not your fault they have used the wrong stuff,it depends on how much you have actually paid for the oil they supplied,you may have to pay the difference from the wrong stuff to the correct genuine stuff.
Ok thanks. I'll ask them. What is the correct stuff so I can ask them what they used?
Thanks. What is the best way forward? Without trying to sound like a wimp, I'm not the best with confrontation, so when I ring and they inevitably argue that they've used the right stuff, how can I further it?  Drove the car again this morning (from cold) and it feels like it's driving with the handbrake half on.  MPG is down, performance is slightly down and the gear changes are clunky and stiff :/
