fuel pump?
Hi to all could anyone help,I put petrol in my 01 octavia 2.0l petrol today and then it wouldnt start,the engine was spinning but wouldnt catch,i have since noticed that i couldnt hear fuel pump priming when i switch ignition on,ive checked fuse and replaced relay bt no joy could anyone help,is it the pump i need to change???? thanks for any replies :dull:  :dull:
Is the relay operating?
i havent checked it but i changed it,should there be an audible click when i open door or switch ignition on,thank you for help
You can or you can feel it operating. You can also check for a voltage at F28 or across pins 1 and 4 at the fuel pump (blue/red and brown wires).
wow you can change the pump from inside? Its under the back seat?
That's good to know. I thought it was a tank removal job.
I used Rob's handy guide when I did my fuel pump internals. As he says, it is a simple job that can be done inside the car, but I hated all the squeaking plastic noises when pulling the thing out and dismantling the pot for fear of breaking something and rendering my car useless!
That's why I posted the guide - it was a bit of a scary job for me to do and I didn't find much online showing the process. I wasn't keen on the open top of the tank with all of that petrol exposed to the air either.
