My third Yeti
A comprehensive report.  Thanks for that!  What winters are you using?
The tyres are stored in a garage 30 miles away, but from memory are: http://www.hankooktire.com/global/passenger-cars-tires/hankook-winter-i-cept-evo-w310.html
They are 205/55/16 94W (??XL) and in conjunction with 16" steel rims have been run for 2 winters now. In that time I've found them hard wearing and effective.
I also have a set of Michelin Alpin A4, which were approximately twice the cost (bought at the last minute from Cost-co), but equally as effective. These allowed me to run an Auto CLK (RWD / >200 BHP) throughout the winter.
The last few sets of tyres have been sourced from Reifen.com. They deliver quickly and don't tend to run out of stock when demand for winter tyres is high.
Thanks again - useful info for the record.
Yes, a well detailed report. BRISKODA is great for this kind of info,unfortunately we occasionally suffer from
un-reasoned ' I don't like that - so it must be BAD ' posts. This is not one of those.
Incidentally, how do you store 'winters' ? On their side, in a pile or standing upright on their treads?
Tyres off rim should be 'racked' vertically (as in tyre depots) and on a rim horizontally. Use wheel trees myself, which work well and are not overly expensive.
http://www.amazon.co.uk/gp/product/B00647X8MU/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
TP
Thanx, plumber. I SAID good info on BRISKODA!!
As per TP - I have two tyre trees for storing them. They were fairly inexpensive (Amazon ~ £20) and we're recommended to me in order to avoid the issues associated with storing tyres flat / stacked etc.
I agree that tyre trees are best, but unfortunately they do take up a fair bit of room in an otherwise full garage. I have to store my winters vertically, ie on the rims against the garage wall, two hung on hooks and two stood on wedges (and rotated every couple of weeks) to prevent rolling along the floor but with no extra weight on them and all with a couple of psi extra in.
Steve.
Nice report and good to see some informed opinions from owning multiple Yetis.
We have a 2.0 CR170 4x4, 1.2 DSG and 1.6 CR Greenline in the family, on top of a tuned 1.8tsi 4x4.
My Yeti also has the Pirreli P Zero Rosso tyres (from new) and I'm so impressed with them it's just had it's second set at 37,000 miles.
I use 225/55/17 winters (so an extra 5 in the side profile) which gives a slightly softer ride, slightly more ground clearance and are about as big as you can go before rubbing on full lock.  Also made the speedo bang on.
But I only put them on for it's first winter as last winter was mild and I was using the car less.
Interesting to note that at 70mph your 6 speed is showing 1900 rpm.
Our first 170 tdi and second 1.6 tdi 5 speed both showed identical 2100 rpm at an indicated 70mph.
Maybe the new Facelifts have a higher 6th gear now which would make a lot of sense?
Hi pinkpanther,
Haveing Diesel Experience since 1978, have you a Manual/or/ Auto Box.
Diesels/Petrols being new need higher Rev's, I used my Auto DSG in select mode and made sure that Rev's didn't go below 2,000,
(unless on the Highway, then I use Auto). Until my first service at 15,000 KM, The less strain on Motor/Drivetrain etc, then  until 30,000KM, will ensure longevity.
Service Manager said to me after recent service, how have you ensured, that you can maintain this excellence, told him the above,
" His comment was that he  needed to ensure "Salespeople" offer the same advice"
1982 Hilux Diesel, 1987 Hilux Diesel, 1992 Disco TD5 Diesel (All over 385,000 KM)
Geoff
You've got me thinking now - I'll go and check for certain and report back.
Hi pinkpanther,
Geoff
My current cars are both manual. The last auto's I owned were a 2005 Lexus GS300 SE and a CRV Petrol Auto - both traditional 5 speed torque convertor autos.
Hi Bossfox, maybe I should give them a little time to bed in. I ran Goodyear efficient grip performance on my last few cars and found them to be good in the wet, quiet and beneficial to my fuel economy. The P zeros seem a little worse in the wet and somewhat noisier by comparison (??? older design than the Goodyear's).
The EU tyre ratings have the Goodyear's as B for fuel economy, A for wet grip and 68 dB for noise, whereas the Pirelli's are F for fuel economy, B for wet grip and 71 bB for noise. I don't have a feel for the accuracy of these ratings yet, but my personal observations seem to bear out the primary differences between the two.
Ultimately (without a great deal of expense) few of us have the option of deciding what tyres a new car is supplied with. Mine have come with a huge selection - Goodyear, Bridgestone, Pirelli etc
The P zeros seem a slightly odd choice for a Yeti though, given their documented sporting bias. I guess it is purely "luck off the draw" and dependent upon which supplier offers the best deal.
Equally odd, my Yeti does see track work from time to time.
This is where I found the P Zeros very capable and hence the replacement like for like. :)
I am currently trying the Goodyears on my Fabia.
TIBET III (FL CR170) in 6th gear at 70mph indicated, is turning at 2050rpm.
At 70mph true which is 73.5mph indicated (GPS verified - speedo 5% under read), it is 2150rpm.
I haven't heard of any gearbox change between pre and post FL but I can't remember what TIBETs I and II pulled in 6th.
Just to clarify my earlier post - at an indicated 70 MPH the rev counter is reading 1900 RPM on my current 140 BHP 4x4 (my old 110 2WD would have pulled just over 2K revs at an indicated 70 MPH).
