Which Front Shock Absorbers are correct for Skoda 1Z5 1.6Tdi with RoughRoad Design 2UB ?
Hello,
Can anyone inform me what should be the correct Front Shock Absorbers to Maintain the spec of Rough road (2UB) on a Skoda Octavia Combi II (1Z5) ?
Original Shocks Code: 1K0 412 021 KP
I Believe current codes should be : 1K0 413 031 EJ or 1K0 413 031 BL (can anyone confirm ?)
Im considering Bilstein but it's hard to find the correct part number for Rough Road.
If anyone knows the part numbers of SACHS or KYB also please inform.
Diameter of shocks housing = 50 mm
Best Regards.
  • Sponsor
Look for another sticker, lower down on original shocks. This isn't the part number you're looking for, there will be a sticker with a number ending 413 031 xx which will give you the correct suffix.
I Believe them to be, but would like to confirm : 1K0 413 031 EJ or 1K0 413 031 BL
1Z5 1.6tdi CAYC
  • Sponsor
Need VIN to look up properly, if you won't look for the sticker. I'll message you so you can tell me the VIN privately.
  • Sponsor
Confirming 1K0 413 031 BL (dropped in Oct 2023) superseded by 1K0 413 031 EJ.
Can you tell me a Bilstein or KYB Compatible part number ?
IBelieve KYB will be 334 834 but Bilstein is very hard to be sure.
  • Sponsor
Sorry, I don't have any such capability. @Carlston may be the man to help with this.
