Blonde mechainc :P
Need help to find the placing of the sparkpluggs :) And what do i look for to check if they are bad?
Car: skoda octavia 2007, 1,4 tsi
This is the engine :)
You need to remove that plastic cover first.
The you will be presented with the coil packs and wiring.
Unplug the coil packs and then lift them off. You will probably need a removal tool like this to avoid damage to them:
http://www.awesomegti.com/schwaben-1-4tsi-coilpack-removal-tool
The spark plugs are then under them.
Phil
Not what I expected upon reading the title......was expecting a bust lass with the odd oily mark on her face!!
Maybe it's just my gutter mind!
Get a professional. Or at least someone who is not a complete novice.
If you don't know these things then you shouldn't be messing around under
there. I can't imagine what you expect to achieve if you don't know where to
find what you're looking for or what to look for once you find it.
It is very easy to cross thread a sparkplug and you'll end up with an expensive repair.
Cleaning the engine bay wouldn't go amiss either.
I'll not encourage you to attempt DIY that is clearly beyond your skills.
I shan't post a pic of the works van engine bay then :rofl:
