Might have gearbox trouble
HI
When changing gear 1/2/4/5/6 are fine but 3rd is a bit funny when you go to change and you get hold of the gear stick you can feel the engine really noticeable like every piston banging as if it is going through the selector shaft its really bad when going up hill and i change to 4th.  Only happens in 3rd but changes fine
Any one else had this or is it dealer time
Sorry to hear this.
Might be worth getting the dealer to check the gear selector cable adjustments.
With mine it's 4th that seems more susceptible to engine transmitted feedback but also difficult to separate from what I'm getting from the tyres.
TP
Just a thought but are you in that gear at too lower rpm or is it more of a selection problem?
No i change around 2000rpm think its more gear than enything
I some times have trouble getting ours in to revers?
