What display do I have?
vRS N00b here.
I've bought a FL Octavia, first registered in February 2012. Can anyone tell me the type of display that I have?
I'm pretty sure it's not Maxidot bit I'm wondering can it be upgraded using VCDS or some software update?
A picture of the console is in the attached file.
Thanks in advance for any info.
Al.
Cheers Softscoop.
Thanks for the reply - I was pretty sure I didn't have the Maxidot & sorry, that's about the only thread I didn't view.
Swopping out the cluster & re-coding sounds expensive & probably more trouble than it's worth I guess.
Next one will be better specced ;-)
thanks again
Al.
Eddie-NL can swap them over for you at a very reasonable price with your correct mileage and imobiliser coding. You'll have to find a FL maxidot cluster in mph for a TDI which could be quite a challenge. When I was looking for one I could only get a standard non vrs one:
which looks good, it just doesn't look quite stock.
I got mine from http://www.skodateile.cz/ this guy is very helpful. It seems that kph ones are still reasonably easy to find. Maxi dot is one of those options that allow you to build on a lot, bluetooth, nav, etc. It's a pity that most cars weren't speced with it new, it was one of the cheaper options on the list.
Hi Slavish,
I'm based in Ireland so unfortunately a trip across to Eddie-NL is really out. My vRS was bought in the UK & brought over here.
Thankfully I've got both MPH & KPH on the display.
You are right in saying that the Maxidot does allow us to build on bits n' bobs but with the mileage I'm doing (900/week just for work) , I'd be hoping to change her next year & I'm not sure if the outlay would be worth it.
Am I right in saying that a lot of options can be enabled/disabled with the use of a VCDS? My local Indy has one.
Al.
Hi Slavish,
Al.
Yes everything that you would find in the options menu of maxidot you can change with VCDS and loads more.
Cheers, appreciate it!
Al.
