windscreen wipers
Wipers have stoped working the fuse is fine
I was told before about Xenon kit will end up blowing the motor which I know assume has happened :(
and..............................
Just letting everyone know that if they put the a non canbus kit in to get it coded other wise have a wiper motor ready
What do the lights do to the wiper motor to burn it out???. This is a very strange one.
Not sure but something to do with the xenon hid kit I was told about a while ago
Cheers, cars are getting far to complicated.
Does anyone know where the fuse for the windscreen wipers is located
These are the dash fuses and does not state windscreen wipers anywhere
01 02 03 04 05 06 \
|____07 08 09 10 11 \
|____12 13 14 15 16 1718192021 |
| 22 23 24 25 26 27 28 29 30 31 |
| 32 33 34 35 36 37 38 39 /
| 40 41 42 43 44 45 /
| 46 47 48 49 /
______________
01: Diagnostic socket 10A
02: Control unit for ABS, ESP 5A
03: Airbag 5A
04: Heating, Air conditioning system, Reverse lights 5A
05: Control unit for headlamp beam adjustment 5A
06: Instrument cluster, Control unit for automatic gearbox, Control unit for electromechanical power steering 5A
07: Telephone preinstallation 5A
08: Towing device 5A
09: Not assigned
10: Not assigned
11: Parking aid 5A
12: Central locking control unit 10A
13: Diagnostic socket, Light switch, Brake light 10A
14: Control unit for automatic gearbox, Selector lever lock 5A
15: Central control unit -interior lights 7.5A
16: Climatronic 10A
17: Not assigned
18: Parking aid 5A
19: Not assigned
20: Uphill-Start off-Assist 5A
21: Not assigned
22: Air blower for Climatronic 40A
23: Front power window 30A
24: Cigarette lighter 25A
25: Rear window heater, Auxiliary heater 25A
26: Power socket in the luggage compartment 20A
27: Fuel pump relay 15A
28: Not assigned
29: Engine control unit, Crankcase ventilation heater 10A
30: Injection valves (diesel engine) 10A
31: Vacuum pump 20A/Control unit for Haldex coupling (4x4) 5A
32: Rear power window 30A
33: Electric sliding/tilting roof 25A
34: Not assigned
35: Anti-theft alarm system 5A
36: Headlight cleaning system 20A
37: Front seat heating 30A
38: Not assigned
39: Control unit for automatic gearbox 20A
40: Air blower for heating and air conditioning 40A
41: Rear window wiper 15A
42: Wipe wash pump for windscreen 15A
43: Towing device 15A
44: Towing device 20A
45: Towing device 15A
46: Heated windscreen washer nozzles 5A
47: Relay for auxiliary heating 5A
48: Not assigned
49: Light switch 5A
Not all electrical loads are protected by fuses.
This is why the HID kits can affect the wipers as the adverse currents fry controllers instead of popping fuses.
Gone are the days where you have a big relay in the dash to control the intermittent wipers function. It is now controled electronically, the same as the auto wipers function and indicators.
So there's no fuse for the wipers /:
It would be foolish of a manufacturer not to protect electrical loads with fuses. Unfused wires have the very real potential to catch fire, a nightmare whilst under warranty, the exception to this is usually the main supply to the starter motor due to extremely high current, hence the diameter of the cable.
Back to the question, engine compartment, F31 30a rating, according to my owners book page 259.
Just messaged my brother an told him have a look as car is with him will let you know once I'm. Updated thanks for the reply
The info I posted is for version 1 fusebox, if you have version 2 it will be F19 also 30 amp.
Skoda approved mechanic has said due to the 35w ballast xenon kit is why it has gone which I new
Should I just buy the 55w ballast will this cure future problems??
Or will coding via vcds be better ?
The 55W ballast will be worse. It is these higher powered ballasts that are rumoured to cause the issues?
The 35W kits are supposed to be OK. I think the issue here might be that you fitted a non-CANBUS kit before carrying out the coding.
Where did you get your HID kit from? The eBay seller London Colour is well reputed on here...
http://www.briskoda.net/forums/topic/264447-hid-aftermaket-kit-help-for-definitive-how-to/page-1?hl=+hid
On.the forum it says to use non canbus 35w kit then code
However I fitted the kit an did not get it coded
I think I will take the kit out fit standard bulbs do sone research and go from there
smileonimpact is right, there is a fuse for the front wipers.
It is in the fusebox in the engine bay rather than the one inside the car on the end of the dash.
According to the manual there are two different types of under bonnet fuse box.
Depending on which one you have it is in either position F31 (Type 1) or F19 (Type 2) - both a 30A fuse.
Edited by silver1011
In case its is just a coincidence, and the cause is not related to incorrect electrofu, my first Octavia had the wipers stop working 6 weeeks after the end of warranty. Dealer refysed to even look at it (Farmers Leics, will not reuse).
So feeling poor at the time, I had a look and it turned out to be the wiper spindles seized. A strip and greasing worked as there obviously had not been any grease there ever before.
New rack was fairly expensive I think, so it stayed like it was until fragged.
I thought only canbus HID kits with capacitors fried the wiper motor and/or controller? I've not heard of the non canbus kits damaging anything.
I hope if someone has had a problem they will post here as I'm having my HID kit out if its going to damage anything, not risking being stuck miles from home in the rain with no wipers!
Edited by paddypaws
You need the non canbus hid kkit fitted and programmed via vcds
Yep, got a non canbus kit programmed in with VCDS. I'm just surprised the programming has anything to do with stopping wiper motor damage after all doesn't it just stop the bulb errors being shown?
I think what it is doing is programming the car for the 35w bulbs from the hid kit so when the bulb blows the power doesn't get diverted to the wiper motor causing it to blow, something along them.lines
No No and trice NO!!!
It doesn't work like that. AT. ALL.
Care to explain what it does do then
Its the massive (relative) capacitors and resistors that screw up current flow and reverse discharge through the common earth of the headlights and wiper motor that causes the damage.
Edited by Metblackrat
