Water in the wheel well
Hi folks,
Two days ago I had a puncture needing me to swap to the spare wheel.
When I lifted the space saver and all the associated paraphenalia out, I noticed about half an inch of water.
Any ideas where it may be coming from? I've never had this amount of water ingress in any other car I've owned.
Does it smell of screenwash?
Sent from my HTC One_M8 using Tapatalk
Not really sure, I'll give it a good sniffing later. But it wasn't noticable when I scooped it all out.
In which case it is unlikely to be a leaking rear washer pipe which means water is getting in from outside. The common reasons are usually the seal around the high level brake light on estates, the boot lid seal or the bonding of the glass to the lid. Only way of finding out is taking the carpet out and sitting in the boot whilst someone hoses the rear of the car.
Missing bung in the spare wheel well?
Would it not drain out though?
Haha! Plus unless it was right in the line of a rear wheel spray you wouldn't get much water ingress I'd have thought? And it would be pretty manky grotty water
Rear light seals? This used to be the culprit on MKII Mondeos...
When it happened a 2nd time the garage suggested drilling drainage holes in the wheel well...
:D you did tell them you wanted LESS water in the wheel well didn't you??
Is it WHEELLY deep ?
