P1246 code
Hi I recently bought a mk4 golf gti 1,8t AUQ
last week I was driving around and the temp gauge slowly dropped to nearly zero then engine management light came on !
I took it to my friend who put is machine on and it said cooling temp sensor fault !
I bought a sensor from euro car parts and it fixed problem, however, today I was driving car and the same thing happened again, so I got someone else to check problem and code P1246 came up on diagnostics !
I've been informed possibly a faulty thermostat !
Can anybody help pls !
as soon as i started reading that i was thinking - thermostat gone/going... before even mentioning the temp sensor...
See here:
http://wiki.ross-tech.com/wiki/index.php/17654/P1246/004678
17654/P1246/004678
17654/P1246/004678 - Needle Lift Sensor (G80): Implausible Signal
Possible Symptoms
  • Malfunction Indicator Light (MIL) ON
  • Engine misfiring/juddering/running rough
  • Engine shutting down
Possible Causes
  • Fuel Supply interrupted/faulty
    • Fuel Tank (temporary) empty
    • Fuel Filter blocked
    • Air in Fuel System
  • Wiring and/or Connector(s) from/to Needle Lift Sensor (G80) faulty
  • Needle Lift Sensor (G80) faulty
  • Injection Pump faulty
Possible Solutions
  • Check Fuel Supply
    • Check Fuel Level
    • Check/Replace Fuel Filter
    • Check for Air in Fuel System
  • Check Wiring and/or Connector(s) from/to Needle Lift Sensor (G80)
  • Check/Replace Needle Lift Sensor (G80)
  • Check Injection Pump
Special Notes
Edited by silver1011
