Auxillary belt tensioner diesel models
Hi guys, has anybody ever tried to replace the auxillary belt tensioner on the aef Diesel engine? It looks like you have to remove the alternator, it's tucked right up under the injection pump and it's looking like a proper pig of a job too.
there's a strange L shaped bar that feeds through the alternator mounting bracket and pushes into the tensioner which is mounted on the other side.
Hi tom,
i had to do this on my first caddy pickup mk2 same as feli. i removed the rad and was changing the alternator anyways. so yes it makes job a lot easier
thanks paddy
Ah yes, remove the radiator, I must admit I didn't think of that, that's a tricky job in itself. Might as well stick q new freewheel clutch on the alternator at the same time whilst it's off.
yep its a pain wish i had done that last time, as mine i think is going as its cherps when cold and goes quiet again when warm?
paddy
Yes mine sometimes chirps a bit, although I must say I thought the noise was coming from the tensioner roller
I hope I'm not stating the obvious remove the front grille as well to give better access. Unfortunately one of the bolts securing the alternator hides behind the the auxiliary belt pully release the tension by using the nut under the injector pump at the back of the alternator it's a strange shape, mole grips do nicely and possibly the wife to hold them this should allow access to the second alternator bolt. Finally don't forget the pulley bolt is a left-hand thread. Best of luck with small fingers clive
What a total plonker I am Please ignore my previous post it's quite an easy job remove the air filter lid and base remove the top of the camshaft belt cover and amazing it's very easy to get at. Leave the tension on the belt as you undo it (left-hand thread) go for the ring spanner on nut and hit it with a hammer approach to shock it loose now the only awkward bit is releasing the tension at the back of the alternator with the funny thing I don't know what it's called by the back of the fuel pump
Simples
I got a quote for both parts of the aux belt tensioner, best part of 100 quid trade price.
  • 1 year later...
I replaced the tensioner spring at the weekend, in order to stop the chirping. I think it was a total of 4 bolts which needed to come out/go back in. It took 3-4 hours of contorting, swearing, dropping tiny bolts, swearing skinning knuckles, swearing etc before I had everything back together! Whilst doing the job, I found the l shaped shaft was dry and very worn. ar5e! No way of getting this out to replace without removing engine or cutting a hole in the inner wing. Once it was back together, I had lessened, but not eradicated the chirping, double ar5e!
I think now that my engine has passed it's 180,000 mile 'birthday' it may well be time to do the tdi engine swap I've been putting off for 5 years!? Now then, what happened to all the mk3 Golf tdis over the past 5 years?!
Edited by jonny a
