bluetooth
Hi i have a seat leon mk2. was told to come on to this site from seatcupra.net to try find out anwsers to why my bluetooth is not working.
i am getting voltage to some of the pins at the module in the car but when done an auto scan it was not talking and it has never worked since i have owned the in july 2013 and got told that it needs a complete software update to work with my iphone 5s.
model number of bluetooth module is 5P0862335B. i have the RNS510 sat nav unit fitted which is 5P0035680A.
can anyone help out to why it is not working?
this is the autoscan.
thanks in advance.
Mike
Chassis type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72 77
01 - engine - status: OK 0000
03 - ABS brakes - status: OK 0000
04 - steering angle - status: OK 0000
08 - HVAC - status: OK 0000
09 - cent. Elect - status: malfunction 0010
15 - airbags - status: OK 0000
16 - steering wheel - status: OK 0000
17 - instruments - status: OK 0000
19 - CAN gateway - status: malfunction 0010
25 - immobiliser - status: OK 0000
37 - navigation - status: malfunction 1010
42 - door elect, driver - status: OK 0000
44 - steering assist - status: OK 0000
46 - central conv - status: malfunction 0010
52 - door elect, pass - status: OK 0000
56 - radio - status: malfunction 1010
62 - door, rear left - status: OK 0000
72 - door, rear right - status: OK 0000
77 - telephone - status: cannot be reached 1100
address 01: engine           Labels: 03G-906-016-BKC.lbl
part no SW: 03G 906 021 SC.      HW: 03G 906 021 AN
component: R4 1.9L EDCS G000SG 1438
revision: --H08-- serial number SEX7Z0H83130H6
coding: 0050071
shop#. WSC 66565 257 00032
VCID: 72E1CE786D7B258E927-8027
no faults found
readiness: 0 0 0 0 0
Address 03: ABS brakes (-----).        Labels: 1K0-907-379-60B
part no SW: 1K0 907 379 AD      HW: 1K0 907 379 AD
Component: ESP MK60EC1    H35 0104
revision: 00H35001
coding: 133B201209240002C80B04E8902000813400
shop#. WSC 04941 000 00000
VCID: 74EDC860D76F2BBE80B-8021
no fault code found.
address 09: cent. Elect.      Labels: 3C0-937-049-30.H.lbl
part no SW: 3C8 937 049 E.     HW: 3C8 937 049 E
component: bordnetz-SG       H54 2602
revision: 00H54000   Serial number: 00000005864137
coding: 81880F2F00041000431D00000000000000007F075C40000C0
shop#. WSC 06402 785 00200
VCID: 336F0B7C52E16C86591-8066
subsystem 1- part no:1P0 955 119 B     Labels: 1KX-955-119.CLB
component: wischer 300608 002 0601
coding: 00056208
shop#. WSC 06402
1 fault found
01504 - bulb for license-plate light (X)
012 - electrical fault in circuit - intermittent
freeze frame:
fault status: 00101100
fault priority: 2
fault frequency: 5
reset counter: 150
mileage: 51511km
time indication: 0
freeze frame:
ON
voltage: 11.85V
ON
ON
OFF
OFF
OFF
Address 15: airbags.     Labels: 5N0-959-655.lbl
part no SW: 5N0 959 655 A.    HW: 5N0 959 655 A
component: J234_A03 VW10 HI  1815
revision: 19013000.   Serial number: 0039DPDP46T+
coding: 0012339
VCID: 3B7F235C7AB1A4C6811-806E
subsystem 1 - serial number: 6333FTS665711788
subsystem 2 - serial number: 6343FTS610751788
Subsystem 3 - serial number: 6353ETS6DFBQUVNH
subsystem 4 - serial number: 6363ETS6TUPLUVNP
subsystem 5 - serial number: 00000000000000000
subsystem 6 - serial number: 00000000000000000
address 16: steering wheel.      Labels: 1K0-953-549-MY8.lbl
part no SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
component: J0527   7520101
coding: 0002042
VCID: 840D18A0C7CF9B3E30B-80D1
subsystem 1 - part no: XXXXXXXXXXX
Component: E0221    002 0010
no fault cod found.
address 17: instruments.     Labels: 1K0-920-xxx-17.lbl
part no: 1P0 920 947 B
component: KOMBIINSTRUMENT V03 0750
coding: 0002401
shop#. WSC 18069 210 95564
VCID: 32610E78ADFB658E527-8067
no fault code found
address 19: CAN Gateway.     Labels: 1K0-907-530-V3.clb
part no SW: 1K0 907 530 Q.  HW: 1K0 907 951
component: J533_Gareway    H16 0202
revision: H16    Serial number: 2700K087100971
coding: E9807F064006020203
VCID: 356B35645C9572B6775-8060
3 faults found
01303 - Telephone transceiver (R36)
004- no signal/communication
Freeze frame :
Fault status: 01100100
Fault priority: 2
Fault frequency: 1
Reset counter: 142
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:16:46
01300 - control module for navigation with CDROM (J401)
004 - no signal/communication - intermittent
Freeze frame:
Fault status: 00100100
Fault priority: 2
Fault frequency: 254
Reset counter: 151
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:20:00
01304 - radio
Freeze frame:
Fault priority: 2
Reset counter: 151
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:20:00
address 25: immobilizer.      Labels: 1T0-035-680.clb
component: IMMO      V03 0750
shop#. WSC 00000 000 00000
no fault codes found.
address 37: navigation (J0506)     Labels: 1T0-035-680.clb
Part no SW: 5P0 035 680 A       HW: 5P0 035 680 A
component: RNS-MID     H05 1036
revision: AB001001     Serial number: SEZ6Z7L9137058
coding: 0C000440040200030020
shop#. WSC 00829 210 91891
VCID: 2C5D10004FDF337E18B-8079
4 faults found
00880 - connection to speaker rear left
freeze frame:
fault priority: 5
fault frequency: 1
reset counter: 126
mileage: 51160km
time indication: 0
00856 - radio antenna
011 - open circuit - intermittent
freeze frame:
fault status: 00101011
fault priority: 5
fault frequency: 2
reset counter: 149
mileage: 51568km
time indication: 0
Freeze frame :
Fault status: 01100000
Fault priority: 5
Fault frequency: 1
Reset counter: 142
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:16:46
00862 - antenna for GPS navigation (R50/R52)
011 - open circuit
Freeze frame:
Fault priority: 5
Fault frequency: 18
Reset counter: 112
mileage: 30189km
time indication: 0
date: 2000.00.00
time: 17:32:14
Address 42: door elect, driver      Labels: 1K0-959-701-MAX3.lbl
part no SW: 1T0 959 701 L          HW: 1K0 959 793 P
component: J386   TUER-SG FT    1518
revision: 71009005      Serial number: 00000295288510
coding: 0004784
shop#. WSC 00829 210 97507
VCID: 408554B01357C71ED43-8015
address 44: steering assist         Labels: 1Kx-909-14x-44.clb
part no: 1K0 909 144 C
component: EPS_ZFLS KL. 77     2301
revision: 00H15000
VCID: 2A511618852B2D2D4EE7-807F
address 46: Central conv.       Labels: 1K0-959-433-MAX.clb
Part no SW: 1K0 959 433 BT     HW: 1K0 959 433 BT
component: KSG PQ35 G2   020 0204
revision: 00020000     Serial number: 00000000000000
coding: 198000405283CC7F7F00850560085F86F07C00
shop#. WSC 00829 210 90032
VCID: 830F1BBCC2C19C06091-80D6
subsystem 5 - part no: 1P0 951 171
component: innenraumueberw.010 4971
coding: 00000000
shop#. WSC 00829
subsystem 6 - part no: 1K0 951 605 C
component: LIN BACKUP HORN H03 1301
subsystem 7 - component        NGS n.mounted
1 fault found
01135 - interior monitoring sensors
freeze frame:
fault status: 00100100
fault priority: 4
fUlt frequency: 2
reset counter: 151
time indication: 0
address 52: door elect, pass      Labels: 1K0-959-702-MAX3.lbl
part no SW: 1T0 959 702 L        HW: 1K0 959 792 P
component: J387   TUER-SG BT    1518
revision: 71009005      Serial number: 00000278388505
coding: 0004784
VCID: 418351B4185DCE16DBD-8014
no fault code found
address 56: radio (J0506)      Labels: 1T0-035-680.clb
4 faults found
freeze frame:
fault priority: 5
fault frequency: 1
reset counter: 126
mileage: 51160km
time indication: 0
Freeze frame:
fault priority: 5
fault frequency: 2
reset counter: 149
mileage: 51568km
time indication: 0
Freeze frame :
Fault priority: 5
Fault frequency: 1
Reset counter: 142
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:16:46
011 - open circuit
Freeze frame:
Fault priority: 5
Fault frequency: 18
Reset counter: 112
mileage: 30189
time indication: 0
date: 2000.00.00
time: 17:32:14
address 62: door, rear left         Labels: 1K0-959-703-GEN3.lbl
pert no SW: 1K0 959 703 AF      HW: 1K0 959 795 S
component: J388  TUER-SG HL    1401
revision: 11006001     Serial number: 00000003318110
coding: 0000144
VCID: 74EDC860176F2BBE80B-8021
Address 72: door, rear right       Labels: 1K0-959-704-GEN3.lbl
part no SW: 1K0 959 704 AF      HW: 1K0 959 794 S
component: J389   TUER-SG  HR    1401
revision: 11006001     Serial number: 00000003328954
coding: 0000144
VCID: 75EBF5641C1532B6B75-8020
[code]
coding: 0050071
no faults found
revision: 00H35001
coding: 00056208
shop#. WSC 06402
1 fault found
freeze frame:
fault priority: 2
fault frequency: 5
reset counter: 150
mileage: 51511km
time indication: 0
freeze frame:
ON
voltage: 11.85V
ON
ON
OFF
OFF
OFF
coding: 0012339
coding: 0002042
no fault cod found.
coding: 0002401
no fault code found
3 faults found
Freeze frame :
Fault priority: 2
Fault frequency: 1
Reset counter: 142
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:16:46
Freeze frame:
Fault priority: 2
Reset counter: 151
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:20:00
01304 - radio
Freeze frame:
Fault priority: 2
Reset counter: 151
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:20:00
4 faults found
freeze frame:
fault priority: 5
fault frequency: 1
reset counter: 126
mileage: 51160km
time indication: 0
freeze frame:
fault priority: 5
fault frequency: 2
reset counter: 149
mileage: 51568km
time indication: 0
Freeze frame :
Fault priority: 5
Fault frequency: 1
Reset counter: 142
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:16:46
011 - open circuit
Freeze frame:
Fault priority: 5
Fault frequency: 18
Reset counter: 112
mileage: 30189km
time indication: 0
date: 2000.00.00
time: 17:32:14
coding: 0004784
revision: 00H15000
coding: 00000000
shop#. WSC 00829
1 fault found
freeze frame:
fault priority: 4
fUlt frequency: 2
reset counter: 151
time indication: 0
coding: 0004784
no fault code found
4 faults found
freeze frame:
fault priority: 5
fault frequency: 1
reset counter: 126
mileage: 51160km
time indication: 0
Freeze frame:
fault priority: 5
fault frequency: 2
reset counter: 149
mileage: 51568km
time indication: 0
Freeze frame :
Fault priority: 5
Fault frequency: 1
Reset counter: 142
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:16:46
011 - open circuit
Freeze frame:
Fault priority: 5
Fault frequency: 18
Reset counter: 112
mileage: 30189
time indication: 0
date: 2000.00.00
time: 17:32:14
coding: 0000144
coding: 0000144
no fault code found
Address 77: Telephone
cannot be reached[/code]
no fault code found
cannot be reached
Welcome Mike
Can you please include the rest of the scan as it also has important info in it (software version and car details ... You can edit the last 3 digits of the chassis number if you like)
That's all I got with the scan I think. What else do you require? And I'll see if I can find out.
The part number of that module looks similar to the part number of my Dad's module in his 08 a3. It might just be too old to work with the rns510? It also seems possible that there are some wiring issues in the loom looking at scan results.
Okay. I'm getting voltage on some of the pins at the module. Btw the sat nav and radio work so god no's why picked faults up with it.
I was thinking a canbus wiring issue rather than a power issue as its not communicating with the gateway or the head unit. Look for a break or a loose pin in the plug from the twisted pair (the can wires) that goes into the Bluetooth unit?
Okay. I'll need to unplug both ends and check continuity with a multimeter. Could the module be at fault tho since it's not talking to it?
Certainly not impossible but they are pretty hardy things! If you have continuity I might be tempted to change it. I think it's fairly old. How old is the car?
It's a 2009 plate. Never worked since I have owned it in July 2013. Okay I'll try that soon. It's finding time and the weather to do it in scotland.
Its not much better down here. Got a smashed patio table to deal with today thanks to the wind.
Not good. It was meant to be bad last night but was okay. We're still waiting on 2 more storms coming.
Clear the fault codes and see what reappears. Post back a new scan after that.
If this is a factory fitted module the canbus connections may not connect to the back of the head unit, since they can connect anywhere on the canbus data network. The whole point of canbus is to remove unnecessary wiring. All the Bluetooth module needs is a connection to can hi, can low and power to actually power up and be seen by the car.
Assuming this is an original install, then If wiring is suspect you could buy the bluetooth retrofit cable and bypass the factory loom all together.
I do have some concern with the age of that module, I suspect it will neither support the iPhone or indeed bluetooth music streaming.
Yes it was factory fitted. But clearing it still not going to make the Bluetooth work tho as its not talking to it.
So what am I best doing?
What Manny says about CAN wiring is correct but because its a network I think any two points are effectively joined so if there is a break, continuity would be compromised and I believe the continuity test is valid. If continuity is present then a module issue is most likely, if not you could try a new bypass loom as Manny suggested.
Either way I agree you probably need to change the module for an iPhone connection.
Do you no what module number would work if I was to replace it after I have checked the continuity?
I am not familiar with the Leon. What type of driver info system does it have? In your RNS510 coding is the BAP setting ticked or not?
I could not tell. It has a display in the left hand cluster with has mpg and direction and can change it on the right hand stalk. Will that be on the unit itself? It mutes when you press phone button.
You are probably safest with a 7p6035730j or later or a 5k0035730d or above module which work with IPhones and can be paired from the phone end even if they don't show in the driver info system. The more premium modules require the newer dis for pairing.
Muting like you describe usually indicates no module is present which is effectively what you have currently.
Okay so I'm better getting 7P6035730J then for working with my phone is what your saying?
Yeah something must not be right. I'm not bothered if it shows in the display or not as long as it works.
Given no proper knowledge of whether you have a full dis or which version it is I would say yes.
Where can I find which display I have and version?
I don't enough about the Leon to advise sorry. If you look in the coding for the RNS510 and see if the BAP setting is checked that will help determine if it is using the newer BAP or older DDP comms protocol (no tick). If no tick you have the older protocol and so you are a more or less limited to the above quoted modules with an iPhone anyway.
Okay I'll need to use vagcom to look it up I'm guessing. I'll have a quick look in the server menu.
