Are some options just ECU turn on's
Hello Everybody. Been having a good look at the new Fabia and am a little confused about how some of the options justify the cost. They seam to be just a bit of programming in the ECU, for example:
The SEL comes with KESSY GO (start only) as standard, make this into KESSY (entry & start) and they want £160. Only thing I can think is an additional sensor in the rear so it knows your stood by the boot.
Driver fatigue sensor - this monitors how you drive you drive to decide if your finished. £50 option on all models but seams like just a program in the ECU.
Light Assistant is standard on SEL but Light & Rain Assistant is and additional £125 but from my limited understanding uses the same sensor in the windscreen. My only thought was a different wiper stalk possibly.
Cornering front fog lights £130 option on SEL as all ready has fog lights as standard. Is this a different unit with an additional bulb in which would justify the cost or again is it just a program in the ECU that needs turning on.
Smartgate - Really not sure on this one could need a wifi access point installing but talking to a AA man recently and he was saying this is the way things are going, they will come out to see you and before they have even got out of the van will have scanned the ECU for errors wirelessly. Clever stuff but also scary in the world in which people want to hack everything!
Just wondered if there were any Skoda guru's out there that could answer the question? or any one got a different opinion on it all.
I would think a few of these could be ECU controlled yes, however, if someone hooked up a laptop, you would think Skoda would be wary of this that people could just hack the car and get the features for nothing.  Maybe there are different versions of the firmware when different options are loaded at final build.
Cornering fogs - I would expect there's a motor added to do this?  How often is it foggy..? can't justify the costs when the headlights themselves don't corner..
Rain Assistant.. rather annoying wouldn't want it.. I'm hoping there's a kill switch for the Light Assistant aswell..
KESSY - not a fan of push button starting.. apparantly if you're within 1.5metres of the car you can gain entry.  I'm seeing if I can get an SEL without it on..
Driver fatigue.. I think it will annoy me too much.. I know when I'm tired.. I don't need telling.. besides.. I've got a wife who'll do the same thing.. £50 saved!
Surprised they can scan an ECU wirelessly.. with the car switched off.. that means its constantly transmitting which will be draining the battery and that doesn't make any sense whatsoever..
On my Octavia Vrs High beam assist was a £300 option, mine turned on for a bottle of Red.
I would think the Fabia would be the same, somethings just need turning on
Anyone with VAGCOM can tap into the ECU and change different parameters, there's quite a few on here that can do and some dealers will do it if you ask them nicely, I had a couple of things changed by my dealer when I bought it.
Cornering fog lights don't need motors, the fog light comes on automatically when you turn so the left will come on when turning left and vice versa, so can be activated by a laptop as no parts needed.
I doubt they'll build an SE L without KESSY as it's standard spec not an optional extra like it would be on an SE, you may need to buy an SE and pay over the odds to spec it like an SE L.
I think having read things again on the tech sheets.. the key is still used on the SEL, but it's used in conjunction with the Start Button, but the Kessy GO means you don't have to insert the Key, just keep it within 1.5m and press the button.. don't like it personally.. but there we go.
And if that's how those cornering fogs work, that's a bit of a cop out..
I understand what you say about the VAGCOM.. prefer to get my own copy of it though.. It doesn't stop dealers turning off features when you take your car in for service though!
kessy to me reduces security
non kessy,
you have a remote or key to enter vehicle (first security factor), then to start the car you need a key  to turn (second security factor) and the immobiliser chip in the key (third security factor)
with kessy
key within 1.5 mtrs to enter the vehicle ( first security factor) , then to start the car you need a the same key within the car and push a button (still only 1 security factor)
some keyless start systems need the remote placed in a slot in dash I assume this is for the immobiliser so maximum 2 factor security as opposed to 3 factor with keys, but with the information about how VAG and range rovers are taken does not look like you need to have an immobiliser chip
I hooked my VCDS clone (12.12.0) to Fabia III and was able to see very few modules so I decided to go for the original cable from Ross-Tech. When I received it I was able to see much more modules - see below scan (I changed VIn, WSC and serial numbers to avoid identification of the car and delaer who provided me the car for testing):
Saturday,10,January,2015,08:48:26:12646
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.0.0
Data version: 20141022
VIN: XXXXXXXXXXXXXXXXX   License Plate: XXXXXXXX
Mileage: XXXXXXXXXXXXX   Repair Order: XXXXXXXXXXXX
Chassis Type: NJ (6C0)
Scan: 01 03 05 08 09 10 13 15 17 19 2B 44 5F
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
Address 01: Engine (J623-CJZC)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BB    HW: 04E 907 309 AF
   Component: 1.2l R4 TSI   H21 8228
   Revision: R4H21---
   Coding: 01110032232415080000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ECM12TFS01104E906027BB 001006
   ROD: EV_ECM12TFS01104E906027BB.rod
   VCID: 65C180BE6450A009FCD-8030
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0003
   Serial number: XXXXXXXXXXXXXX
   Coding: 41F5247D492433C0091B106E0054822492CC9008000DCAF98F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
   ROD: N/A
   VCID: 33652EE69A040EB9A29-8066
No ASAM data for: "EV_Brake1ESP90iBOSCHPQ26" ()
Address 05: Acc/Start Auth. (J518)       Labels: 5Q0-959-435.clb
   Part No SW: 5Q0 959 435 A    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0604
   Revision: 00021000    Serial number: XXXXXXXXXXX
   Coding: 030C0C
   ASAM Dataset: EV_KessyHellaMQBAB 002011
   ROD: EV_KessyHellaMQBAB_VW37.rod
   VCID: 3A7B03C2BD6EFFF161F-806F
Address 08: Auto HVAC (J255)       Labels: None
   Part No SW: 6V0 907 044     HW: 6V0 907 044
   Component: Climatronic   H01 0105
   Coding: 100000001011100001
   ASAM Dataset: EV_ACClimaValeoPQ26 003001
   ROD: EV_ACClimaValeoPQ26.rod
   VCID: 74E7EDFADF8A49817B3-8021
Address 09: Cent. Elect. (J519)       Labels: None
   Part No SW: 6C0 937 090 B    HW: 6C0 937 090
   Component: BCM PQ26 HiKR H07 0065
   Coding: 0C01085042050AFB43804000402703080800D900D2013500000000000000
   ASAM Dataset: EV_BCMA0 004008
   ROD: EV_BCMA0.rod
   VCID: 275DCAB65EDC72190E1-8072
   Subsystem 1 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A
   Component: RLHS  037 0059
   Serial number: XXXXXXXXXXXXXXXXXXXXX
   Coding: 00185E
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 D    HW: 5Q0 919 283
   Component: PARKHILFE 3K  H10 0048
   Revision: --------    Serial number: XXXXXXXXXXXXXX
   Coding: 0001050001
   ASAM Dataset: EV_EPHVA14AU3700000 002022
   ROD: EV_EPHVA14AU3700000_VW26.rod
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0304
   Coding: 00000000FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001015
   ROD: EV_ACCMRRBoschVW372_AU37.rod
   VCID: 387F19CA8362EDE197B-806D
Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
   Part No SW: 6C0 959 655 F    HW: 6C0 959 655 F
   Component: VW20Airbag023 001 0340
   Coding: 88CCC000000000005C5400CF000800000000
   ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 366317F289761B91857-8063
   Crash sensor for side airbag; driver side:
   Subsystem 1 - Part No SW: -----------    HW: 410 820 211 14
   Component: SideSensor_Df  151 0800
   Coding: 2D2D2D
   Crash sensor for side airbag; front passenger side:
   Subsystem 2 - Part No SW: -----------    HW: 410 820 211 14
   Component: SideSensor_Pf  151 0800
   Serial number: XXXXXXXXXXXXXXXXXXXXXX
   Coding: 2D2D2D
   Crash sensor for side airbag; rear; driver side:
   Subsystem 3 - Part No SW: -----------    HW: 442 150 111 14
   Component: SideSensor_Dr  1CA 0148
   Serial number: XXXXXXXXXXXXXXXXXXXXXXX
   Coding: 2D2D2D
   Crash sensor for side airbag; rear; passenger side:
   Subsystem 4 - Part No SW: -----------    HW: 442 150 111 14
   Component: SideSensor_Pr  1CA 0148
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels: None
   Part No SW: 6V0 920 740     HW: 6V0 920 740
   Component: KOMBI         214 0290
   Coding: 072401102180000801882A011000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009040
   ROD: N/A
   VCID: 72EBEBE2A59E47B169F-8027
No ASAM data for: "EV_DashBoardVDDMQBAB" ()
Address 19: CAN Gateway (J533)       Labels: None
   Part No SW: 6C0 909 901     HW: 6C0 937 090
   Component: GW MQB A0     H07 0065
   Revision: --------    Serial number: XXXXXXXXXXXXXXXXXXXX
   Coding: 030100042F0A640000000000000000010001050000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear.rod
   Multifunction unit control module:
   Subsystem 1 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
   Component: E221__MFL-PR6  H05 0130
   Serial number: XXXXXXXXXXXXXXXXXXXXXXXXX
   Battery Monitoring Control Module:
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: XXXXXXXXXXXXXXXXXXXXXXXXXX
Address 2B: Steer. Col. Lock (J764)       Labels: 5Q0-905-861.clb
   Part No SW: 5Q0 905 861 A    HW: 5Q0 905 861 A
   Component: ELV-MQBA      H01 0120
   Revision: 00000000    Serial number: XXXXXXXXXXXXXXXXXXXXX
   Coding: 5500000000000000
   ASAM Dataset: EV_ELVMarquMQB 004111
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 34672DFA9F0A0981BB3-8061
Address 44: Steering Assist (J792)       Labels: Redir Fail!
   Part No SW: 6C1 909 144 M    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3211
   Coding: 0007
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: N/A
   VCID: 326B2BE2651E07B1A9F-8067
No ASAM data for: "EV_SteerAssisUDSTRW" ()
Address 5F: Information Electr. (J794)       Labels: None
   Part No SW: 5Q0 035 819     HW: 5Q0 035 819
   Component: MU-S--ER      H11 0133
   Coding: 03620000BE00000011110004000808002F0100C40120010000
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_SE26.rod
   VCID: 70EFE1EAAB9275A19FB-8025
   Media Player Position 1:
   Subsystem 1 - Part No SW: 6V0 919 604     HW: 6V0 919 604
   Component: ABTm_Std2  H40 1022
1 Fault Found:
1637 - Interface for External Media
          U11B8 00 [008] - No Communications
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 44
                    Mileage: 123 km
                    Date: 2014.12.31
                    Time: 13:32:31
End-------------------------(Elapsed Time: 02:53)--------------------------
As Fabia III is based on MQB platform you can play with adaptations to enable new features - IMHO a lot of them, including majority of those listed by carl0076, should work.
More irritating electronic crap to go wrong and drive up the price - another trip down VW lane.
KISS.
Nick
thing is the electronics are a necessary evil for all the gadgets people want for comfort, convenience and safety
if you don't want so much you need to look at the cheaper Korean / indian brands or a car over 10 years old
