DIY Sump Guard/Skid Plate
Hi, new member to these forums.
I was wondering has anyone out there made up a sump guard for the mk2 pre fl or has anyone any info about making one up.
I was trying to figure could i just bolt up some aluminium to where the plastic undertray is or would this work?
Any info is appreciated!
I would have though you could fit the steel sump guard from a Scout in place of your plastic under tray
Ah not too bad, are they standard on all scouts? As in if I went to a wreckers, they should probably have it if it was there?
Thanks! :D
Steel sump guard was standard on prefl scout, I think fl went to a reinforced plastic version
Thanks a lot man, might have saved me a lot of effort.  :clap:
My 2008 scout certainly has a steel sump guard as I have to use a hydraulic jack to lower it when changing the oil
