Help! rSap and the 3 network
I have tried today to set my phone to "GSM Only" and it worked perfect without disconnection, mind you it worked perfect yeaterday (very hit and miss) ... although when it connects via Premium the setting in the phone does not apply, the car still connects to 3G if available..
I will see how it goes, I do not use 3G/4G that often so the setting does not really matter..
I have confirmed that SIM/Network causes issues, my S3 using the same vodafone SIM is hit and miss, the SAME phone with a Virgin SIM worked perfect for 4 months... first time I then used my Vodafone SIM..Disconnected from the car...
  • Replies 50
  • Views 8.7k
  • If it helps...... I have used the following phones all on Three with no problems using RSAP. Nokia 6700 Nokia N8-00 LG G2 mini on Jelly Bean android 4.2.2 LG G3 on lollipop android 5.0 Sko
  • If anyone is local I'm more than happy to have a quick play as my set up is working. Assuming you also have a microsim we can swap bits over to find the problem.
