The new airtec intercooler for the fabia vrs
you should get a licensplate holder for the tow hook hole in the front ant
Greater turbo lag?
ive seen that done before and would like it, but then I don't want the bumper or the little cover bit to get chipped everything I want to take it out for shows etc etc.
I like how it's taller but I don't like the look of it as you can see it. I like it looking oem with forge one.
Get the black one :)
No problems with the Wagner. Lag is still zero with the twincharger setup (plus with the GFB diverter valve).
Trick is to increase the efficiency of the charge cooling system and thus making it as small volume as possible to reduce the amount of air in the system needing compression and therefore turbo lag. Why do you think the latest M-Power motor has the charge cooling designed like that? :)
