Goodyear question
vRS needs two new boots.  I've had Eagle F1 Asymmetric 2 previously and they were brilliant but on the Blackcircles website there is also EfficientGrip Performance as well.
Anyone had experience of the EfficientGrip?  Are they better than the F1s?
Not had the EG variant but the F1s get a thumbs up on the Superb.
F1's are the better tyre in terms of grip
According to the Internet the treadwear rating for the F1AS2 is 300 and it's 340 for the EGP. The EGP is still a very good tyre and should last longer than the F1AS2.
I have a set of F1AS2s on mine but the car had the older design EfficientGrips on when I got it and they were still decent.
I've got the EfficientGrip Perf summer tyres as the OEM fitment on my Yeti and they're OK. They seem to prioritise noise and wear over grip and feel. I'll chnage them for something more feelsome when the time comes, probably Continentals SP5s
Many years ago we had F1 GS-D2 and they were brilliant in the wet. After they stopped being available in our size, and the replacement model also wasn't available our size, I thought about what I most wanted from a tyre and, deciding that I wanted good wet weather grip throughout the life of the tyre, selected Goodyear Hydragrip.
When Hydragrip was no longer available in our size, I moved on to Goodyear Optigrip as that seemed to be the replacement mode. When Optigrip started getting in short supply, I asked Goodyear technical support what model replaced it, and they said Efficient Grip Performance. I hope it's as good in the wet as the earlier tyres ...
The efficient grip is A rated for wet grip
So is the Eagle F1 Asymmetric 2 I believe.
I've just fitted 4 Goodyear F1's on my MKIII Vrs, Impresed withn the Wet/Dry Grip and there quiet
So it is, I right it was lesser rated but checked and you are right.
 Eagle fi asymmetric 2. Is E for fuel, A for wet grip, 69dB
Efficient grip performance is B, A, 68dB
Both seem to get some reviews about getting damaged side walls easily, but generally get good reviews.
I had the efficient grips on a previous car for 15 months, thought they were fine and noticeably better on fuel than previous tyres, but can't confirm the experience with the vrs yet
  • 4 weeks later...
On Saturday I had a pair of Goodyear EGPs fitted - less that £100 each from Black Circles.  Can't comment on the dry grip levels yet as I am still scrubbing them in but they are significantly quieter than the Chinese Ditch-hunters the car came fitted with!  Living in 'sunny' Devon I can also vouch for their water-clearing abilities!
i have f1 fitted and wet and dry grip is excellent and quite quiet as well
Fitted af1's to my vrs sometime ago. Transformed the car. Grip is excellent in both wet and dry
Where is the cheapest place for Goodyear F1's at the moment?
For fabia vrs 205/45/16
Try camskill dude
Thanks, just checked cams kill they have 2 types of Goodyear F1's both the the same price.
One is asymmetric and the other is GSD3 what's the difference between these 2??
And that's saying something from a seasoned Rainsport man :)
What is the wear rate like compared to the Rainsport 3's? I can buy RS3's for £55 a tyre or the F1's for £62. Can't decide which to go for.
Does anyone know the difference?
GSD3s are an older design, not even sure they are still in production. Buy the Asymmetric 2s. :)
Ok thanks mytyres.com are doing them for £68.40 each that's the cheapest I have found.
Tyreleader doing them for £63.99 each!
