Budget big brake upgrade?
This has no doubt been posted but im after a cheap option to a big brake upgrade, would i be looking at an octavia VRS setup? any other options to look at?
Im just thinking calipers off an OE setup that I could get abit cheaper second hand.
Im having issues with uneven braking, the pads are unevenly worn and the car dives so im thinking the calipers might need a refurb but I just want abit better stopping power in general now.
The "normal" brake upgrade is to 312mm brakes from say an Octavia. You may get urn hands on this setup for around £100 give or take.
A "big brake upgrade" such as Brembo from a Seat Leon Cupra R or Tarrox brake callipers for example will set you back £400+
if you are driving a vrs the octy or TT front brakes are a good upgrade,if you are driving a non-vrs then a 288mm setup from the vrs can be had cheap
Yeah im in a mapped VRS, the brakes are shocking! So I could possibly get a TT setup as well?
I wouldnt go down the LCR brembo route as its out of my price range, im just after a cheap upgrade really
Are the line fitments the same? Or will i need new flexy lines?
Yeah you can take it off the Octy and your own brake lines will work also.
I bought mk1 tt calipers. Painted them and put new seals in, was a cheap project with very pleasing results
Bleed the full system witth fresh fluid and get some brembo discs and Ferodo DS pads, cheaper than 312 upgrade and better in my eyes.
i totally agree. :)
anyone tried ebc yellow pads ?
I think you may need bigger wheels than the standard 16" alloys if you were to fit LCR brakes
312's
im running 220bhp atm and the standard brake setup was cooked in 2 miles if I drove like a tit got tarox setup now and have tried to cook them and I can't !
Have look in for sale section some have just popped up there.
TT brakes setup
Decent discs and pads.
Had 312mm on my last VRS and shocking braking compared to aftermarket discs and mintex pads on my current stock brakes.
Use your noddle then
Uprated pads and new discs on 312's will murder the same setup on 288's
Common sense
Has anyone heard of or used Carbotech XP8 or XP10 brake pads? The guy's over on the Pulsar forums swear by them. Apparently the stopping power and it's ability to cope with heat are unrivaled although they suffer from brake squeal due to the nature of the compound.
This is what the owner of one of the Pulsar forums says about them. He knows his stuff and is very well respected over there, maybe worth a look into.
"without a doubt the best pad's on the market at the moment are the carbotech
supreme stopping power over any other pad ive tried so good for fast road and track alike (im running them on my gtr)
they are expensive to buy initially but they last over twice the length of other pads with hard use so are cost affective in the long run
downside is they are noisy and a bit dusty too"
Common sense
Use you're noodle then because you're spending twice as much when the op said he didn't wanna spend much :laugh:
Edited by tommccabevRS
Its all relative
312's discs and pads is 'not that much' imo compared to 323 brembo's discs and pads
Its all relative
I don't think there's a difference in the pad prices on 312's and brembo's it's just the discs. I'm due new discs and pads for my brembos and the Pagid discs on CP4L are about £73 or summet each -.-
Common sense
Ah okay then. Both single pot callipers and pad compound will make far more difference than the surface area difference.
Only IMHO and experience when using my noddle of course :)
Look in forsale 312s with updated disks and pads ton fifty I think, if hadn't already got some 312s I'd be very tempted. Anyone selling 312s pads etc cheap??lol
Which is why i said 312's will be superior to 288's when both using same uprated pads
Plus they dont look like milk bottle tops
I have XP8s in my clio which I use as a track car. Awesome pad but verging on overkill for the road and you need to bed these in well ( i.e. Hammer till smoking) to avoid constant brake squeal which again using my noddle and experience (see above) might be difficult on road and with vrs callipers. I think they do a road pad - bobcat IIRC - and if it's as good as the XP8s it will be perfectly sufficient.
Looking at just over 200 for a set of XP8s.
Okay you win.
Common sense often not as advertised though :)
