POI gone
After firmware updated poi are gone.
Any idea why?
User POIs or system POIs ?
System
Depends what firmware you've updated to and from. Some firmware updates reformat the hard drive and maps/POI etc. need to be reinstalled. Also they might still be there but need reselecting in settings.
Agree with Rustynuts - check the Settings section as they may be in the unit just not switched on.
Failing that I'm out of my depth on upgrades but lots of people on here know them inside out.
Good luck
So how to reinstall map? I have cd
Not 100% on this but I thought if you inserted the CD it would autorun and install maps.
Perhaps try a search using the search box at top of page as there are map threads on this forum about firmware and mapping updates.
Could also try the ICE & Security forum and see if they can help there.
Yes just insert the map DVD and it should then re-install the maps onto the new partition. ;)
Depending on which maps version you have of course. The new firmwares use a different POI system to the old ones, and old maps with new firmware won't give you POI as they're not the same format.
So, what version of firmware was on the unit and what version of maps? And what version of firmware did you upgrade to and what version maps have you got to install?
I don't know what version was before update.
At the moment I have
Map version HDD 6317
SW-Version 4024
HW-Version H11
Yr maps are out of date meaning they still use the old format of POI used prior to the newer firmware you are on. If you upgrade to newer maps (v8 upwards), they should come back.
Thank You Adamal.
Where I can download V.11 maps?
You cannot download the maps legally and any links posted here will be deleted, the only official place to get the updated maps is your a VW Group dealer.
Very helpful Mr perfect :)
My V12 disc is for sale in the classifieds. V11 is old now.
New map V.12 resolve problem.
