Paranoid about DMF. Please help.
Hello everyone, just read lots of horror stories about failed DMFs and I'm getting paranoid as car will be out of warranty soon. Could you please listen to the recordings below and let me know if you can hear anything sinister? Dealer says all is fine, but as I said I'm paranoid.
Car is 2.0 TDI 140 DSG, almost 3 years old, with 37000 miles.
View My Video
View My Video
Edited by jozisko
Sounds pretty normal, though it's hard to tell from a recording as the quality of the sound after recording on a phone microphone and audio compression isn't likely to be very accurate. Have a listen for the metallic noise on this recording and the way it goes away for a while after he blips the throttle for comparison though:
The usual symptoms of a failing DMF are juddering on pulling away no matter how smoothly you let the clutch in (Not to be confused with the slight hesitation felt moving off for the first time when the engine and gearbox oil are cold - this should be long gone by the time the temperature gauge starts to move). Usually as they are failing they develop free play, so sometimes when going from putting power down to overrun such as driving over the top of a hill you'll feel a clunk too.
If there actually is something wrong, don't be tempted to replace the DMF on a common rail TDI with a single mass flywheel as there have been enough reports of crankshaft and bearing failures as a result of the extra stress a single mass flywheel transfers to the rest of the engine on these units. The CR's were designed for DMF from the beginning while older engines got DMFs as add-ons after being designed for single mass originally.
The best test for a worn DMF is to accelerate hard at a slow speed (30mph) in too high a gear (6th).
If it judders all is not well.
I get slight vibration when I do this. But that was always the case I don't think it vibrates more than it ever used to.
Thanks for the replys guys.
To preserve the life of the DMF it is advisable to minimise the strain you place upon it.
For this reason I often change down earlier, keep the revs a little higher than usual and definitely ignore the gear change indicator on the dash - this is designed purely for improved fuel consumption - not the longevity of the mechanicals.
My thought is that a few extra pounds spent on fuel is easy shadowed by a premature DMF replacement.
mine is DSG, so I don't change manually very often
Ah in that case I'm guessing that the life of your DMF is in the hands of the mechatronics!
A failed DMF sounds like an old metal dustbin full of spanners kicked down the road, calming a bit when the revs go up
BUT they can also simulate a slipping clutch when the springs start to collapse
£1000 covers it
Bough my used 2010 superb 2 months ago, had it 2 weeks when noticed odd sound. A new dmf, clutch and a reconditioned gearbox housing (clutch breaking up damaged it) later cost the garage I bought it off £1750!!! Just to cheer you up!
hello all,
            12/12 140 s combi manual. just completed 143k in 2 years plus.
             no hint of dmf probs.
BTW, i have been told that the DSG setup is - in fact - TWO manual gearboxes with a DMF.....
bring back proper auto's i say!
Given the low chances of manufacturing defects these days DMF failures are largely driver induced.
If they've been towing heavy things or riding the clutch will put pay to the dmf
There are 2 alternatives to the usual LUK DMF
a SMF and the better planetary DMF made by Sachs
hello all,
Is that miles? Either way that is a serious amount of driving in that time!
hello,
       that,s miles.   3 problems along the way.
       fuel tank sender unit seal@ 19k,
       clutch master cyl @ 107k,
       alternator failure @ 134k, otherwise faultless.
       now sold @ bought a 13/63 140 s combi dsg.
      a doodle to drive @ hopefully reliable.
      thankyou to all forum members for great info.
                       cheers.
to paraphrase an old music hall song
You cant drive a modern like an old time diesel cos it wont last all that long
no more using low RPM and chugging along like a 2.5di transit or Pug 504
