Carista OBD2 - A cheaper alternative to (some of) VCDS
I have lost the side DLR's on my facelift Superb using this Carista app, I seem to have changed DLRs to low beam and now cannot reset even using the MFD option.
I have email Carista regarding this issue.
  • Replies 171
  • Views 64.1k
  • Pirate hardware, software etc is operated by the same organisations controlling drugs, human trafficking etc. Its easy to explain these things away as harmless, the truth is, they are far from it.
  • What can I say, I'm a true yorkshireman... careful with the pennies
  • For the princely sum of £9.88, I'm in this for sh*ts and giggles: http://www.amazon.co.uk/gp/aw/d/B00DYOVXZ0 And this extension cable, to tuck the dongle out of the way so that I can have live g-met
If you don't hear back from them let me know, there are a few things that can be checked to find out why they aren't working using better tools.
Thanks for the offer.
Well after emailing my issue through the app and also PMing them on Facebook I have heard nothing from Carista.
Stubs
can i defeat the seatbelt warning bong?
Yes reach under each front seat, locate the wire from the seatbelt clip on the centre tunnel follow it about 6 inches and you will find the joint, and unclip them, job done
Edited by skippy41
Carista finally came back to me regarding the loss of my MK2 facelift DLRs. I have sent them a bug dump which they are reviewing at the moment.
Stubs
anyone got a link to an adaptor that will allow customisations in carista?
Can only be used for gasoline engine, can not be used in diesel engine
Well I used it to set up the DLR for fogs and then back to low beam when I was trying to resolve the side DLR issue, and mine a 2 litlre diesel
I bit the bulet and got one, had to download the pay version, it did a check and kept on coming back are the doors open?? they where, so just actualy opened them all, then it was OK, no more seatbelt bongs, 5 flash indicators ,
No faults found
No faults found
which?
I was under the impression that all facelift skodas had side DLRs in the new shape headlights but after spending a weekend in Belfast and seeing lots of Skoda Superb I believe this is only the high end Elegance option. So the Carista app did not loose my side DLR's as they weren't there to start with.
I have emailed Carista apologizing for my error.
Quick question, if i change the country to europe will i get the large kph display on the maxidot? and will it change my headlights to point in the wrong direction? I'm in ireland,
2012 elegance estate
Someone mentioned above, that eg.
Mini OBD2 ELM327 V2.1 Bluetooth Car Scanner Android
is working with Petrol Engines ONLY
Can anyone confirm it? I don't believe 2000+ buyers have Petrol engine only.... I have Diesel... and what now? I'm going to use it with Carista....
I am using the same device to configure my diesel as stated.
i simply stated what the seller had posted
  • 1 year later...
Hi all just used carista today great little device but does anyone know what the engine code fault 04985 Skoda Yeti 170 4x4 any ideas?
Text File.txt
You have this in your file:
Steering angle
[failed to connect]
