Carista OBD2 - A cheaper alternative to (some of) VCDS
If having issues. Do a scan. Turn bluetooth off then let the app turn it back on
Sent from my Galaxy S5
  • Replies 171
  • Views 64.1k
  • Pirate hardware, software etc is operated by the same organisations controlling drugs, human trafficking etc. Its easy to explain these things away as harmless, the truth is, they are far from it.
  • What can I say, I'm a true yorkshireman... careful with the pennies
  • For the princely sum of £9.88, I'm in this for sh*ts and giggles: http://www.amazon.co.uk/gp/aw/d/B00DYOVXZ0 And this extension cable, to tuck the dongle out of the way so that I can have live g-met
I'll have another play tomorrow. I did try switching bluetooth on/off. Letting the app connect and connecting manually in BT settings but got nowhere. Hopefully my 3rd adapter should turn up tomorrow!
Not so sure about this now. Bought a wifi OBD11 reader from Amazon. Bought Carista. Yesterday tried it on my Jan 2014 Superb L&K read all the codes so far so good. Thought I would try changing some settings. Changed the number of lane change flashes to 5, changed coming home lights to spots. Left it at that. Tried my wife's Corsa, could not get any readings, sent massage to Carista who suggested that it could be the wifi unit. Today came to try out the changes I made to the Superb nome of them had changed, did another scan and the Carista showed up as the new settings but still no change response from the car.
Any thoughts anyone?
Update:
Sorry forgot to update this post. Having contacted Carista, they helpfully explained that after making the changes, I need to go into the maxidot seating sand change the default to manufacture or something like that. This resolved the problem and all my changes were effective.
Edited by Raptor
this doesn't work on my 2012 elegance either. Contacted Carista customer support, but no reply yet.
This is what is (supposedly) can be configured on my 2005 Octavia II 2.0PD TDi 140 Estate:
Doors / Windows / Remote
Auto-unlock doors when key is taken out of ignition
YES / *NO*
Beep when locking with remote
YES / *NO*
Beep when unlocking with remote
YES / *NO*
Blink turn signals when locking with remote
*YES* / NO
Blink turn signals when unlocking with remote
*YES* / NO
Beep when locking with key
YES / *NO*
Beep when unlocking with key
YES / *NO*
Blink turn signals when locking with key
*YES* / NO
Blink turn signals when unlocking with key
*YES* / NO
Beep when alarm is armed
YES / *NO*
Blink turn signals when alarm is armed
*YES* / NO
Unlock doors via remote
*DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS
Enable settings for opening/closing windows and sunroof
*YES* / NO
Open/close windows and sunroof via long-press on remote
*YES* / NO
Open windows via long-press on remote
*YES* / NO
Close windows via long-press on remote
*YES* / NO
Open sunroof via long-press on remote
*YES* / NO
Close sunroof via long-press on remote
*YES* / NO
Sunroof action when opening via remote
*SLIDE* / TILT
Open/close windows and sunroof by holding key in driver-side door lock
*YES* / NO
Open/close windows and sunroof by holding key in passenger-side door lock
*YES* / NO
Open/close windows and sunroof by holding key in trunk lock
*YES* / NO
Open windows by holding key in door lock
*YES* / NO
Close windows by holding key in door lock
*YES* / NO
Open sunroof by holding key in door lock
*YES* / NO
Close sunroof by holding key in door lock
*YES* / NO
Alarm system
*ENABLED* / DISABLED
Alarm system disarming
VIA REMOTE OR KEY / *VIA REMOTE ONLY*
Re-lock doors automatically if you unlock, but don't open a door
YES / *NO*
Enable remote control buttons when ignition is on
*YES* / NO
Delay alarm activation
*YES* / NO
Instruments / Display / Dings
Instrument cluster region (affects ext. lights too)
GERMANY / EUROPE / USA / CANADA / *GREAT BRITAIN* / JAPAN / SAUDI ARABIA / AUSTRALIA
Seat belt warning
Lane-change turn signal auto-flasher
Lights
Daytime running lights
*OFF* / ALL LIGHTS / HEADLIGHTS ONLY
Coming-home lights
ENABLED / *DISABLED*
Leaving-home lights
Coming-home lights mode
*BASED ON PERSONALIZATION* / AUTOMATIC
Rear fog lights
Flash brake lights in emergency stopping
YES / *NO*
Other
Lower passenger-side mirror when in reverse gear (req. memory seats)
YES / *NO*
Additional 'tear' wipe after rear window washer use
YES / *NO*
Auto-enable rear wiper when front wipers on (interval) and reverse gear engaged
*YES* / NO
Auto-enable rear wiper when front wipers on (continuous) and reverse gear engaged
*YES* / NO
However, the one-press unlocking feature wasn't accepted, and setting the rear fog light to 'enabled' actually disabled my rear fog light - I was hoping it would switch on the LH one.  Changing it back switched the single for light back on.  I enabled the rear tear-drop wipe & alarm beep successfully.  Also, every time I try to interrogate the modules (whatever the detailed scan option is), it gets to 100%, goes blank and crashes, on both an iphone 4S and iphone 5C.
Ah well, another defective device apparently :/
Given up for now, will just find someone with VCDS.
Quick question for anyone with a working Bluetooth adapter - what code does yours use to pair?
All 3 of mine use 1234, the adverts say to try 3 different codes. I'm wondering if different codes depict different hardware in the adapters.
I use 1234 and works perfectly
Well that blows that theory away!
[snip]
I've managed to enable the one-click unlock, so it seems mine is a bit hit-and-miss.  I still can't get the detailed check to run without crashing, but I've cleared the three glowplug faults that I had (they haven't returned), and done most of the customisation I wanted, so it's good value.
The difficulty is understanding where the problem lies, with the software or the OBD reader. I have sent a debug report to Carista, waiting for their reply.
Right, had some success today :)
WiFi and girlfriends old iPhone 4 worked a treat.
Scanned and found a couple of codes, most useful being the headlight washers leading me to a blown fuse - washers now work :) Cleared codes fine.
And I paid for the pro version.
Worth £15 just to be able to turn on anti hijack and unlock all on first click.
Also quiet beep on lock/unlock which is handy.
Had less success with extra tear drop wipe on screen wash though - looks like it's activated in the menu but doesn't work. And coming home lights used the xenon headlights - not what I was after.
Will play some more tomorrow :)
Had a reply from Carista. Regarding the lane change, I need to go into the MFD and change the Settings --> Lights and vision --> Factory setting --> OK
This has resulted in my change indicators now doing 5 instead of the standard 3 settings. So a happy chappy and thanks Carista for the support.
This is in response to my post hashtag 129 and 137 above.
Strange, the factory setting on my Superb is for 3 flashes...
Ah! Should've searched better before I bought a Vgate VS450  :doh:
Think I'll get one of these too as they're only a fiver - more things to play with  :nerd:
Is it worth moving these threads from their model-specific forums to the VCDS forum? (I found this via http://www.briskoda.net/forums/topic/364467-wi-fi-car-scanner/ in the Octavia II forum)
Iain
  • 2 months later...
Can you give me the code and other information to update the Carista to PRO version please?
I just would like to try it so I do not want to pay 20USD to play with it.
Thank you in advance
Really?
74k3Ah1k3 should do it... If that doesn't work, try N0ch4nc3 :thumbup:
Hi, Thanks!:)
Where do I have to put this code? Because it always want me to pay via google pay for the pro version
Really?
74k3Ah1k3 should do it... If that doesn't work, try N0ch4nc3 [emoji106]
So.....
Full.....
Of....
Win...
Sent from my D5803 using Tapatalk
Or just pay so the developers can carry on developing the App.
Haha worth a try.....
By the way can you give me your bank account details as I just want to try out that bank before moving my account to them. :D
  • 4 months later...
what is the "Allow configuring daytime running lights via dash display" setting for, how does it work ?
Cheers.
For the Fabia?
The DRL's on the Fabia are turned on and off either using VCDS or by a simple switch on the fuse box. Some cars have the switch others don't.
Perhaps the Carista option allows the turning on and off of the DRL's using the same procedure as other models (indicator stalk) or Maxidot?
Me too, Bryan, and with VCDS changes can always be reversed successfully if a scan is done first - except for the well-known hidden Byte. But this device intrigues me and has me thinking about other software which can be used with a wifi dongle.
I'm going to give the free-ish one a try. The two times I have had the dealer change settings using VCDS they have inadvertently changed other setting too. At least this was I should be able to do it myself....
For the Fabia?
Cheers, for reply. Mine as the switch. fabia monte 2012...
Some interesting reading. Might have to do some more research as my fogs as DRLs at 50% would be great for sub £20
