Name what's currently 'wrong' with your car at this very moment...
Wheel well full of water osf fog out overdue a service
  • Replies 78
  • Views 5.1k
Annoying intermittent 'clonk' sound when pulling away from the nearside front seat when occupied.
Dealer can't get it to replicate to fix it.
Newish Bosch wiper blades,drivers side judders like a juddery thing but not all the time & seems to bear no relation to the amount of water on the screen,oh and the million stone chips & gravel rash on the front.
And the oil catch can that's still sat in the corner of the garage. :sweat:
try flipping the juddery blade the other way aroumd? Worked for me before....
The odd interior rattle
Both front alloys been kerbed
It's a bit slow for me!
BMW - Slight eggy smell when first starting it, very odd. Nothing aside from that.
Octavia - New tyres all round needed, totally covered in scratches, passenger door doesn't lock when I drive away like the rest do, clutch slips slightly if I abuse it, think that's it.
CB1000R - New front pads needed, new tyres soon, needs a clean and paint needs some loving.
It lacks the top half of the engine, turbo, intake, exhaust manifold and a piston :(
To add to mine: needs 4 new tyres soon, needs lowering more :P
Knowing I've clouted two wheels in the last 6 months so they'll need a refurb and that pounding up and down the motorway has caused numerous stone chips. But I still can't justify spending a whole pile of cash on a Mk3 Octavia vRS so it's a keeper.
Both lekky windows knacked on the Roomster - FNS went donkeys ago but the FOS decided to follow suit last week!
Its a spoiler job,could try taking the rubber out & fitting it the other way i suppose.....or take it off & throw it as far as possible lol.
Fantasy Green Estate:
Faulty lambda sensor wiring. Causing it to constantly read rich, thus leaning it out
Worn console bushes
Blowing exhaust flexi
Grumbling release bearing
Broken electric window switches
Worn aux belt tensioner pulley
Alfa GTV
Thread stripped on nearside rear caliper bleed nipple
Currently no nearside rear brake flexi pipe
4 new tyres waiting to be fitted
Where do I start?
Air con not working
Exhaust blowing
Dead wasp needs removing from high level brake light
Knocking noise when cold.
Metallic vibration from underneath at about 2500 rpm.
Needs a bloody good wash inside and out.
Not sure if it's just me being stupid. 2014 octavia vrs estate. Headrests left and right go up and Down but the middle one doesn't come up seems stuck and I'm pushing the button in to try and pull it up.
Spoiler should pop off and on t'other way too??
Mine lidl's finest and was easy enough fully reverse them.
Still get a bit of judder in light drizle at just above motorway limits though!!
Another thing i forgot...
When releasing the clutch at idle, just on the bite...
Something in the passenger door is rattling goodoh! Stops as soon as the revs lift slightly so its resonating with something. Keeps waiting for the window to vanish into the door frame...
It's in Germany when it should have been here ages ago!
Check engine light for SAI pump missing. Resistor not working and local mapper doesn't know how to map it out.
Both need a good clean.
apart from a duff rear wiper motor, nowt.
It works as well as a twelve and a half year old MkI Fabia with 141,000 on the clock should :)
Never broken down, never failed to start.
Failed two MoT's (one for a fog light, the most recent for a bush and pad wear, both fixed on the drive and retested and passed the same day)
63 plate fabia Monte - 14k on the clock- rattles from doors, dash, boot.
Brake callipers need painting green. I was planning to do it over the bank holiday but the weather stopped me.
Front ARB link arms need replacing.
Rear door leaks (has done for at least the last 5 years)
Cooling and air-con fan don't seam to work when air-con is on. (air con fan is stiff)
Needs a wash and seats could do with a clean.
A bloody clonk noise from the front offside, now that I've changed me lower control arms. Appears -- after an extended diagnostic wiggling-and-jiggling-things session by the side of the road with an experienced ex-mechanic -- to be steering related. :devil:
It just doesn't end!
Additions to mine:
Octy boot lights not working
Scratches on driver's door from dog
Stone chips on bonnet.
98,000 miles and stone chips - that's all I will say!
