Name what's currently 'wrong' with your car at this very moment...
Don't let Jack aka Toxicvrs see this thread :notme:
Sent from my Galaxy S5
Right where do I start?
Clio :
Rattle on drivers door annoying me
Slight loss of coolant
Radiator bracket damaged
Under tray missing
Engine mounts perished
Boot lid has loose rattle
Passenger side seat has knackered connector
Combo
Loosing a tonne of coolant
Engine mounts
Handbrake sticking
Gear linkage
Back doors rattling
Crowbar marks on back doors
Servo seal leaking
Wheels full of crap again
Springs soon to need doing
  • Replies 78
  • Views 5.1k
This. :doh:
A biggy i know - the nsf door speaker is rattling (or something inside door is loose) when i play the low bass choons :-(
Also its black and a PITA to keep clean / scratch free
Boot parcel shelf still rattling.
Nothing at all.
So long as I keep the stereo turned up and don't look in the mirrors.
This might take a while,
My VRS,
Needs MOT
Needs interior putting back together
Need to figure out why battery keeps going flat
My XC90,
Needs 4 tyres or new set of wheels
Needs rear control arm bushs replacing
Need to put centre console back in after fitting my dension gateway
My Corsa,
SRS lights on
MOT is due
Not even going to list my 206GTi and 309GTi else i would be here all day
Stil need to get round to having rear drums changed. Rear shocks may be slowly letting go. Rear driver side door staying lock intermittently. Possible bad earth somewhere as i keep getting electrocuted when i close the door getting out after a drive. Temp gauge not going above 80 unless im stopped pointing down hill or hitting mway speeds... rear wiper unit fuse out to stop front wipers staying on constantly and 600mls to next service...
Nothing apart from a small scuff on the n/s/f wheel [emoji19]
I had to take the door carrier off last year and two of the rivets aren't tight enough and it vibrates as I pull away.
Also, when I fitted the splitter, the tape I used to stick it in place before I screwed it in pulled away the paint on the very bottom of the front bumper. Will be fixed in the next couple of weeks.
Octy:
Front and rear bumpers need respraying.
Various bits need paint touching up.
EGR might need cleaning
Drivers seat has a seam that needs stitching.
New rear view mirror needed.
Fabia:
Needs a wash and wax.
Needs some touching up.
The mongrel has now turned to "likely failed injector unit" rather than blown turbo seal or top / bottom end rebuild needing time.
Small escape but still a bit of a pain in the ass.
Kind of need fixing as soon as monies allow:
Very smelly clutch
Rear brake pads having an argument with discs
front left suspension really needs looking at
A full wash - interior and exterior
New front bumper
Niggly bits:
Various electrical thingys not working - rear parking sensors, 12v socket and passenger seat heater
New drivers seat
new set of wipers and rear wiper cap (the cap which directs the water - I don't have one)
Most likely a full repaint as there isn't a panel with a decent scratch on it
Harman/Kardon rear parcel shelf mounted subwoofers rattle over big bumps as I still need to replace the screws. Very annoying when the rattle of the sub out powers the bass at low volumes :(
Oh, boy...
  • Bodywork is a disaster. Minor-ish rust; dents; faded paint; and spots of completely the wrong green where I tried to prevent too much rust.
  • Brakes squealing like stuck pigs, pads 'fine', discs look like records.
  • Blower motor has 2 speeds: Off, and Full.
  • Thermostat is probably disintegrated, car never heats up (and thus runs comically rich constantly) unless stuck in traffic, then...
  • Fan thermostatic switch dead. So radiator fan never turns on; causing it to come unpleasantly close to overheating when sat still for too long.
  • Lower motor mount bushing nearly non-existant.
  • Ball-joint gaiters falling to bits
  • Still missing my near-side wing mirror; due to my laziness.
  • Rear window washer, doesn't.
  • ...and I still haven't got around to wiring in the rev counter I have.
  • Oh! And then there's the crud in the fuel tank/crudded up fuel filter.
It's pretty much all fixable, and I have parts stocked up; it's just a matter of finding the correct tuit, as the ones I have aren't sufficiently circular.
Edited by Tamber
Coolant loss,temperamental drivers window,knocking from either suspension or steering.Other than that it's good
About the only thing I can think of is the rubber strap that stops the fuel cap falling when you undo it has broken (obviously only falls if you don't hold it). Did have an ABS fault coming up for a while but that was sorted with a new rear wheel bearing. Sailed through the MOT recently with just 3 advisories (2 for under trays being fitted and obscuring view and the other for emissions being too low to trigger the test equipment to print a result  :D ). All serviced up for another year so happy days. And yet I still find myself searching/looking at other cars on the NET. Current distraction seems to be the Mazda 3 MPS. :S
Dare I say it........nothing. :x
Addifion to my list -
Passennger window a bit erratic from driver door control. Dosn seems to mean up unless pushed to auto down. And i defny need new rear driver side shock. Very rolly heading to the shop last night when turning left!
Curbed a rear alloy slightly in an avoidance manoeuvre due to a **** veering across the centre line whilst looking down at something (dash, stereo, phone....). So annoyed.
Think I might have a front wheel bearing on the way out.
Still don't know where to put my new Briskoda stickers....decisions, decisions.....
Other than that an utterly outstanding car so far :)
I'm missing a front badge!
It's dirty and the pile of parts to fit is getting bigger......
Front pads at limit
FARB bushes fubar'd
Snapped rear spring
Engine bay (well intact whole car) dirty lol
Oh and my child safety switch on the windows don't work..
It's too small......and maybe a little slow.
Oh wait you mean is it broken? Nah its a perfect Skoda like all of mine have been *touches wood*
Octavia-
Rear wiper motor sticking.
Exhaust mounts dodgy.
Front discs warped.
Rover
Could do with new brakes, there's a bit left but not much.
Passenger electric window switch not working..
Nothing urgent really so that's nice.
