VCDS Tweaks for Mk3 Fabia
Smartgate is a hardware module which sits underneath the drivers seat.. if you didn't order it at the start it wouldn't have got fitted at the factory.. but take note, Smartgate can be hacked remotely - it's not that secure, so I'd probably advise not to buy it until it is improved.. I have disabled mine for security reasons.
i was not talking about Smartgate , but Smartlink functionnality, the functionality is on the system files but not visible on the Bolero ...
  • 4 months later...
  • Replies 191
  • Views 68.6k
  • Just a heads up, but on the Octavia/Golf (MQB) there are several sub menus/activations which are coded info the infotainment (even the basic one) but are set to "not active" in VCDS, so just set to ac
  • Try with NO, if it will not work then choose YES.
  • I Found this site... I think everything possible for fabia is here with instructions...   http://ankk-vagcom.com/category/codages_vagcom/skoda/skoda_fabia_nj/
how can I enable fog lights as cornering lights?
What is added to post week 22 for smartlink? I have asked the question in several posts but no answer has been forthcoming.
Hi Pjm57 after week 22 the control unit for the system was changed from part number 5Q0 035 820 to 5Q0 035 820 A. Im guessing that the new part number contains the wifi communication equipment and software needed for Apple CarPlay and Android auto. This box contains the SD card slot so imagine it sits beside the glovebox and there is a lead that connects it to the Bolero unit. For those people with a VCDS it's module 5F: Information Electr.
Would it be possible for any nice person out there with a week 22 or after Fabia with smartlink to post the auto scan of Module 5F so I can compare the long coding? I was going to pop to the dealers see how much it would be to get the updated part then ask some of the genius's on hear if it might be possible to code a new unit in to get smartlink.
Hear is my autoscan for 5F:
Address 5F: Information Electr. (J794)       Labels: 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 820     HW: 5Q0 035 820
   Component: MU-S-D-ER     H11 0137
   Serial number: SKZAZ2R0085988
   Coding: 03620000BE0000001111120400880A002F0100C60120010000
   Shop #: WSC 73430 790 00048
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_SE25.rod
   VCID: 68DFDA5E937D4B7ED6-803C
   Media Player Position 1:
   Subsystem 1 - Part No SW: 6V0 919 604     HW: 6V0 919 604
   Component: ABTm_Std2  H40 1022
   Serial number: SKZ8Z9RH300GY4
Might also need an adaptation map of 5F to stand a chance of retrofitting. If there are any experts with advise out there would be much appreciated, cheers.
P.S my long code may vary from others as I hid the AM band the original long code was 03620000BE00000011111204008808002F0100C60120010000
If you have a VCDS then:
Taken from the ross tech forum
Found Hear
Module 09, Security Code, enter 31347, then Adaptations and change channels:
(5)-Leuchte12NL LB40-Light_Function_B_12 from not active to Abbiegelicht links
(5)-Leuchte13NL RB3-Light_Function_B_13 from not active to Abbiegelicht rechts
Have tried it on mine and works a treat but as ever take a adaptation map before you start and keep the log running, any changes are made entirely at your own risk.
If you dont have a VCDS use the VCDS map to find one hear you, but not to many in the north sea I'm afraid  :D
These are the tweaks I have done so far with VCDS using version 15.7.4:
Enable Vehicle Path for parking distance sensors.
Module 10 Park/Steer Assist - Coding - Long Coding Helper - Byte 1, Bit 5
post-5279-0-46373000-1460493621_thumb.jpg  post-5279-0-53022000-1460496082_thumb.jpg  post-5279-0-30861100-1460496162_thumb.jpg
Enable Needle Staging, Lap Timer & Display Volume to Replenish
Module 17 Instruments - Coding - Long Coding Helper
Needle Staging - Byte 1, Bit 0
Lap Timer Byte 1 Bit 3
post-5279-0-28753100-1460494232_thumb.jpg  post-5279-0-75232100-1460496290_thumb.jpg  post-5279-0-95706400-1460496295_thumb.jpg
Display volume to replenish - Byte 10, Bit 4
post-5279-0-10625400-1460494417_thumb.jpg  post-5279-0-84270700-1460496393_thumb.jpg
Hide AM Band
Module 5F Information Elerct - Coding - Long Coding Helper - Byte 14, Bit 1
post-5279-0-23494000-1460494712_thumb.jpg  post-5279-0-67114000-1460496387_thumb.jpg
Coding in LED number plate lights
All these I have successfully done on my car but as always any changes you make are done entirely at your own risk.
Edited by carl0076
Found Hear
Module 09, Security Code, enter 31347, then Adaptations and change channels:[/size](5)-Leuchte12NL LB40-Light_Function_B_12 from [/size]not active to [/size]Abbiegelicht links(5)-Leuchte13NL RB3-Light_Function_B_13 from [/size]not active to [/size]Abbiegelicht rechts
Cheers
I have ross tech vcds and have done quite a few tweaks on my Passat B8.
Just got the fabia last week and trying to gather tweaks. I deliberatly did not tick the 100£ option "static cronering lights" becuase I was pretty sure it was just an vcds option
carl0076 - the vehicle path looks cool! Do you know if that is available even with only the rear sensors?
It is awesome I was so pleased when I spotted it as I had seen it on my mates octy mk3, the octy only had rear sensors so yes would imagine it's there for just rear sensors, should be the same module just make sure you have the latest VCDS version as there are way more tags in the long code helper than in previous versions for the fabia
Edited by carl0076
Can anyone confirm they have managed to activate Hill Control and auto locking (anti-hijacking). I have been in touch with MTL and "as far as he can remember" he managed to activate Hill Control". I hope he won't mind me seeking a firmer view. And if people have managed it, are you able to provide the codes?
TIA
I did the cornering lights/fog lights.but now the fog lights are on all the time,not on turning left or right
Edit
Instead of abbiegelicht I had initialy encoded abblendich.thats why thry were on all the time. There is a coding if you want the fog lights as DRL :)
Edited by lans
coding for Hill Hold is:
ABS
Long coding
Byte 22
BIT 0 - activate
WARNING USE AT OWN RISK!
Edited by Welsh_kai_boy
ABS
Long coding
Byte 22
BIT 0 - activate
Is this something a Skoda dealership should be able to do? I phoned mine and the guy wasn't sure if hill hold was only factory fit for a Fabia Colour Edition.
I am afraid I don't know. Give the the code and ask them to try? But I would anticipate they will charge you come what may.
I would expect that they can do it but not in this way. You have to order Hill Hold ''upgrade'', pay it and then they get the code for activation.
Thanks, georgef and mtl. Seems like a bit of an expense and hassle.
Anyone know how to activate the radio station logo settings on a Swing radio??
I have the logos on the SD card, but the required selection box under DAB or FM settings to "grab" the logos from the SD card is not there!
I've had a quick look in the 5F admap I did but nothing stands out at me as of yet!
No need for VCDS - there is a little donkey-work needed though - no "grabbing or "cutting-and-pasting" here !!
Here's the gen you need, fabdav :
http://www.briskoda.net/forums/topic/361220-swing-gen-2-and-station-logos/#entry4313013
Edited by Dithane
I read that post, but it does not help as the radio does not have a setting for "station logos" as shown in your pictures! I am asking if it is possible to ""activate" that setting via VCDS to then be able to reveal the station logos setting to enable you to then load the logos as you state in your post!
Ah - I misread that !  Sorry, man.
Is it an earlier Fabia - MY15? Like late 2014 / early 2015 ?
Think I recall some guys on here saying that they didn't have that option either.   As I recall - they were earlier cars.
I wonder if there's a software update for that version of Swing.
Yep its an early Fabia MK3 basic poverty spec no aircon but the Swing radio with the central dash SD slot as per the photos...
Not my car, just a mates.
I got totally confused when I didn't see the Station logos setting anywhere & had to do a google to make sure I was looking for the right setting....just it ain't there on his radio...
Edited by fabdavrav
hi i am new here ,my name is Barak i have an skoda fabia mk3 and i have noticed annoying thing that the windows are not closing automatic when you close the car door
someone tried to enable this option via VCDS? thanks alot
Unfortunately you can't do that due to the limitations of the door electronics.
Hi
New to skoda. Have Fabia 3 se-l with amundsen.
Thinking of doing some changes via vcds. Is it possible to activate the following via vcds?
Voice control (have button but says not available)
Cornering fog lights
Fatigue alert.
Hill hold.
Dial sweep.
Thanks for any help
Can we sticky a list just to tidy the thread up ??
