Custom brake lines - fittings
I'm in the market for some custom brake hoses, as I'm currently rebuilding a set of Brembo's for the front of my Furby.
Can anyone please confirm the standard fitment dimensions and types as per the HEL page below please?...
http://www.brake-lines.co.uk/create-your-custom-brake-hose.html
Would I be correct in saying that the end that connects to the copper pipe is the 'Swivel Circlip Female' end? Not sure on sizes though...
Also, the middle attachment where it fixes onto the hub with the clip knocked in to hold it in place... which support would that be? I'm assuming either the 'Circlip Large Nut' or 'Circlip Small Nut' ?
Any help would be appreciated please!
Thanks all :):thumbup:
Why go to all the hassle of making you're own when you can just buy LCR brake lines? They're not exactly expensive think I paid about £45 for the fronts on mine lol
The primary reason is that as I'm re-building them I've removed the bracket that goes from the brake caliper level to the top of it. Hence standard LCR lines wouldn't be long enough unless they go straight to the centre of the caliper.
You can see in the picture below where the standard line connects to...
