Terraclean huge problems ! Monte Carlo tdi
Hi guys any of you had issues with terraclean ? Car has been running fine but after reading all the great reviews thought I would give my engine a treat. Take the car for a spin yesterday about an hour after treatment and the thing died. First coil lights on then engine lights then limp mode. Then totally died had to be towed would turn over but not start tiwed by the AA to my local garage. Codes read at roadside as low fuel pressure. P****d off ain't the word . terraclean came this morning and said it was nothing to do with the treatment, yet car was fine yesterday ! Car is stuck in garage now just hope I ain't gonna have a huge bill ! Any thoughts on possible cause ? I would definitely not recommend. Thanks
  • Replies 59
  • Views 87.4k
  • Also sometimes knows as Engine F***ing'.
  • when i took over a large vauxhall franchise as the aftersales manager a few years ago  i was horrified to learn they had been upselling engine flushes on all cars even high mileage vehicles that had n
  • On the plus side I have noticed a slight increase in mpg lol
If I remember well car manufacturers in general don't recommend such treatments.
Edited by 32KOFDATA
What does terraclean actually do?
Causes grief and trials and tribulations and really is not necessary on a modern Euro 5 Emission Diesel engine if they
get the correct Service & Maintenance and good fluids used.
http://terraclean.co.uk/faqs
Edited by goneoffSKi
Oh dear that doesn't sound good! Hope you get it sorted.
Is the car still in warranty?
Not sure there is much point in using these cleaning products on a newish car as not much in the way of deposits will have built up
Uh oh indeed!
Basically they bypass the cars fuel, and run the thing off some magic formula that is apparently meant to clean and de-clog the engine. Gaining economy and performance.
If you have low fuel pressure, it could be something that they did when returning the car to standard?...
Is this also called engine flushing?
OK cause recently I watched this clip and check out what happens to first guy and what the company had to say about engine flushing etc.
We are seeing component failures more regularly as drivers are being sucked in by such 'treatments'.
I can see why he had it done though. I've only sort of heard of it around, and nobody seems to know what to think.
This is maybe proving a point though
when i took over a large vauxhall franchise as the aftersales manager a few years ago  i was horrified to learn they had been upselling engine flushes on all cars even high mileage vehicles that had never been flushed for 8+years
i got into major **** with my divisional bosses but it stopped pretty much over night
pretty much the same with fuel cleaners they used to try and make us sell that at mot time to so called help with the emmissions test
back in the gold old days i used a cheap oil in the engine on tickover for half hour  to get warm and then drain that and fill with the proper stuff
never trusted these so called wonder cleaners
After getting mine Terracleaned a few weeks ago, and after reading this I'm now a little nervous :L
Due for a service fairly soon, so hopefully fresh oil and filters will help keep everything running well. All seems fine at the moment anyway.
nope
Engine flushing is adding an additive to the engine oil just prior to carrying out an oil change.  It's supposed to help remove sludge & clean out oil galleries.  If your oil is starting to sludge I'd recomend less short trips & more frequent oil changes
Uuummm, I remain sceptical of these sort of treatments.
There are plenty enough cleaning additives to the fuel and the engines have filters etc.
Provided you get a regular service a diesel engine properly warmed up and driven normally will last easily 200k miles without any other treatments, which is probably way longer than most of us will own a modern vehicle as first or second owners (excluding taxi drivers etc). I wouldn't even contemplate any additives or specialist treatments to any modern engine.
Hope the OP gets it sorted.
We had low pressure on our van at work was simply a clogged up fuel filter, let's hope it is something simple like that. The terraclean chap may have disturbed something on the high pressure rail?
Edited by Defenderben
Was thinking about getting mine done they do a dpf treatment too, Dont think ill other now tho!
Keep all receipts for the repairs and take him to small claims court, Depending on what the garage find hope it gets fixed
So the car was fine, had the treatment and now it's knackered?
They're claiming it's not the treatment? Hmm ok...
Hi folks. I used to be on another big deisel club forum stdrivers and most peolpe on their don't rate it. Mainly because they keep their cars serviced with proper parts, oils etc. long runs and or regular italian tune up. However, they would also point out that it's the cars that are not looked after that may.....get a something from the Tclean but do run the risk of crap going into place they should not.
But generally we're talking about older cars on the other forum too..
I agree that diesels in particular should run and run but mostly used in the correct way. If your intending on keeping your car for many miles then I would and will use high grade cleaners/additives from a specialist supplier once a year. As been mentioned on this club, BG cleaners are a good starter for problem solving.
More recent car should not need anything unless not driven correctly and a problem occur.
The thing is this is about a euro 5 1.6tdi CR dpf. Prone to issues with sensors without some muppet that works a franchise putting what they call special fuels through the engine.
At some point, all modern vehicles are going to suffer with excessive carbon build up. There's no getting away from that now.
So, eventually the inlet system may require some form of cleaning. But do it right. Remove and clean parts. If you do it in Situ you run the risk of further damage.
The same to be said with the fuel system. If you run a terraclean fuel treatment, it will only last the time it takes for the tank of fuel to empty.
Certain additives are extremely good and can be used safely. Used regularly these can reduce carbon build up/fuel blockages.
I found on the internet some time ago, via a VAG forum, that VAG do have their own version of this inlet tract cleaning stuff to sort out issues with coking up on the direct injection petrol engines. I did enquire about Terraclean and found a local place that does that treatment, but that was as far as I got - it was for wife's old Polo 1.4 16V - but time has run out on that idea!
"TerrorClean" - you rock up in your nice expensive motor. Spotty bespectacled 'technician' gives you the once over, unzips his hose and pumps her full of his special juice..... She's never gonna be the same again....... ;-)
TerraClean applied to a diesel engine.:
Sent from my SM-G900F using Tapatalk
Was it this guy...lol.
