Retrofit ABS controller info TPMS
Does anyone know if my 1k0 907 379 p controller is compatible with the TPMS system?
Side question, does it display any info on maxidot? Since fitting maxidot its become my Panini football sticker album, I spend a fortune but never seem to fill it :P
Doesn't add anything to Maxidot though (unless you go by the name of 'Eddie-NL' and have retro-fitted the newer highline controller with pressure sensors in each wheel).
Looks OK to me from the pictures.
As Mike says, PM Eddie-NL and he'll be able to tell / sell you exactly what you need.
I'll get it and give it a shot for the money. Cheers again folks
What a good choice of stuff that ebay seller has. Not sure how good or bad the prices are, I will be given them a look up when I need bits.
That would be good too, I don't even have a remote fuel cap release, am wondering how much hassle that would be to fit? Would be nice to fill all them blanks as all I have right now is the traction control and airbag light.
That's ok... no Octavia does. The flap is locked/unlocked with the central locking then you push it to open.
Phil
Any ideas how easy it would be to fit Phil? I saw a button on ebay must have been a MK1. Its a pain having to lock and unlock fuel cap with a key.
Ah right. So does the flap/door not lock with the car on yours?
On mine it's locked when the car is locked (you can hear a little motor in there). Then to open the flap you push it then just unscrew the cap.
Phil
No Phil,even when locked I can open it and the cap itself has a lock on it. Takes a fair bit of faff to unlock too as you have to hold the cap with one hand whilst turning the key a full turn or so.
I'm guessing I could fit the motor and wire it into central locking?
Just realised I dont think I can fit the tpms as I don't have esp I have asr :( I presume I can't wire I to that button? How annoying lol
You can fit TPMS with only ASR :)
Seconded, my car has TPMS and ASR from factory.
I have ASR and I fitted TPMS :)
Edited by Phil-E
Thanks guys have the abs plug off just got to wire in the single wire now if I can work out how the hell to open this giant plug lol. What a faff it is
Ok I give in, can anyone help lol.also I thought I better check as you never know, it us the giant plug on the abs I am tapping into right? :)
Yes. The locking mechanism lifts about 2inches before it budges - basically much more than you think it needs to....
I managed to get it out cheers adamal but I don't know how to open the plug to put the wire in
Yes softscoop, I didn't want to force it of as don't seem to be able to work out which part separates from which.
If I remember rightly, it has 4 locking tabs. I think I just carefully levered it off.
