Skoda Pickup Battery
1 hour ago, Zimo said:
Then again in the morning start is good.
That has to do with a phenomenon known as "overnight battery recovery."
R u joking!?!?
By the way, i think that the new one needs to be used some times to get to the max power , isn't it?
Edited by Zimo
R u joking!?!?
https://www.quora.com/Can-a-car-battery-recharge-itself-overnight
https://electronics.howstuffworks.com/everyday-tech/question390.htm
Moreover, I witnessed the same too. Remember, I said RECOVERY, not recharged.
I don't think so.
Edited by RicardoM
40 minutes ago, RicardoM said:
I don't think so.
It actually does and it is called lead acid formatting period.
The battery will gain approximately 10-20% more capacity.
Actually that applies only to deep-cycle batteries that are designed to be regularly deeply discharged using most of their capacity. In contrast, starter/cranking automotive batteries are designed to deliver only a small part of their capacity in a short, high-current burst for cranking the engine. It is a different kettle of fish.
Another question:
Can the health of the battery affect negatively the fuel consumption?
Yes. What exactly do you have in mind?
16 hours ago, Zimo said:
Another question:
Yes the alternator will put for effort into charging therefore more load on the engine.
Therefore more fue consumption.
Before the battery gone bad felly use 25km/L . In the last 2 weeks we are around 20km/L . The only things changed are in order:
-winter tires(but i drove 500km to grap the hard cover for the bed and consumpiotn pretty close)
-brake cylinder
-battery
So i was wondering if the battery influeces the consumpiont
Ok simple.... didn't see your answer
15 hours ago, RicardoM said:
There is one more thing that changed in an infamous, stealthy way. The weather 😎
https://www.fueleconomy.gov/feg/coldweather.shtml
http://www.sp3h.com/blog/107/
Ok good.... and still is not harsh winter, my trip to work is 25 km of provincial roads free of traffic jam. Have to re-check tire pressure(apart from one that i had puncture 3 days ago sigh...sigh the only one that the shop used a impact gun over torqued and lost 2 hours to get back on street! Argh argh)
30 minutes ago, RicardoM said:
How fanny u are! 😠 the problem is that i needed a long tube (1.5m) to unscrew thw bolts because there were over tight!
Little edit
Hot start problem  seems solved! And this morning i had to go back to tire shop because the repairex tire deflate ....rapired again!
I think you didn't get it. The video is a clever example of using the weight of the car to your advantage when there is not a cheater bar handy and all you have is the jack of the car...
Sorry my fault! But i think that that suggestion didn't work as well because a bent a regular crick key with extension on ! And bent also the spare key !
