ABS Pump
Hi I have a Skoda Octavia 1.9tdi 2008 that has a leak on the ABS pump it is leaking where the bowl meets the block can this be repaired  as I have been quoted £500 for a new one then I have to get it coded and reprogrammed I have just had to replace the clutch master cylinder and hose at a cost of £170 so if I can get it repaired it will keep the costs down.
Edited by kimba0773
