Metallic click still there?
So a while back i posted a thread that i can't find now about how i have a metallic clicking sound from the front right o/s wheel under load, i have managed to get a video of it if anyone could have a listen and maybe suggest i have had the wheel off and used a pry bar there is no loose joints or lower arms or anything of the sort the brake pads are nice and tight so its not them wobbling around so just trying to explore a bit more ?
No one :/
It said i had to sign in to watch it?
could be a cv joint?
I was thinking that but it just had its service and he also sad he couldn't find anything and I'm sure it would have been noticeable on test ?
Changed the video privacy settings :D
Ill have anothr listen in the morning and see what i can hear.
cv joint might be only a little worn and so isnt causing any audible issue when weight is off it on a ramp or turning at a low speed?
I thought when you said 'Under Load; you meant Under Load,.  not when moving off.
At least it is going to be easy to find when someone is there right next to it diagnosing the noise and not running alongside up a hill.
