Uniroyal rainsport 3
Anyone tried these on TDI vrs ?
I run these all round, I would recommend them but make sure you pay a bit more for the XL (extra load) ones as they do have soft sidewalls.
They are a very grippy tyre but don't expect the wear rate to be fantastic as they are quite a soft compound. Depending in how you drive I'd expect to see 7-10k out of a front pair, maybe a touch more if you don't drive it too hard.
In terms of grip these things are on another level compared to the set of Kumhos I had on previously. Grip in the dry is fantastic, you'll struggle to get the traction control to kick in even off the line in 1st/2nd gear. In the wet they are also very good, you can usually use full power in 2nd gear without too much fuss and I'm running a mild stage 1 map. They also feel a lot safer in the wet compared to the Kumhos which felt a bit skittish in comparison even just driving relatively normally.
Edited by mattbvRS
^Agreed fantastic tyre especially for the price. I've recently brought my 3rd pair and will continue to use them in the future.
I had 4 of these fitted earlier this year with a rarb and the car was transformed (rarb makes the biggest difference). The grip on these are immense in the dry and very good in the wet too. :thumbup:
I'm on my second set of these, bloody awesome and no brainer against the standard premium ones or Kumhos etc.
I hope they never go premium pricing !
Good tyre lates 22k ish mainly motorway miles but 3 laps of the ring ruined them and the handling was not great with them the side walls are too soft even with 35pso in them. Im on hankooks now amd prefer them.
I have them as my summer wheels. I've bought them in may and after 10.000km are looking pretty good. I haven't showed them mercy cornering, accelerating or braking and my car doesn't have abs nor traction control. I think they will last at least another 2 seasons and then swap rears with the fronts. Check the air pressure and wheel alignment. Those are good tires, awsome priced with cool performance. However, they don't perform well under 7 celsius degrees,so you might want to get the winter tires fitted during the cold season.
I used to have these on my focus st excellent tyres
Ive fitteda set on my octy vrs. Spot on tyres, maybe all round better than Eagle F1 Aymetric 2 but i havent wuite decided yet.
