Amunsen MIB1 Firmware
15 minutes ago, Miagi09 said:
Hi guys,
Would anyone be so kind and send me link to newest software for my Amundsen Mib1?
Thank you in advance /cdn-cgi/mirage/782220f56ac0820981fbf9e56bd8af0cd22904a8750d34f8a52256b01f18ace3/1280/https://www.briskoda.net/forums/uploads/emoticons/emoticon-0100-smile.gif
/cdn-cgi/mirage/782220f56ac0820981fbf9e56bd8af0cd22904a8750d34f8a52256b01f18ace3/1280/https://www.briskoda.net/forums/uploads/monthly_2022_12/IMG_3831.thumb.JPEG.73cd66d95d2772b5f5da25eba5e5829c.JPEG
I will send you a link soon via Private message function.
  • Replies 982
  • Views 227.2k
  • I have updated my Amundsen from 0435 to a newer version which can be found on the net. I don't want to share the link here to avoid deletion but I will kindly PM it together with the instructions.
  • If you have instructions they'd be appreciated
  • Guys,   From now on a newer firmware is available for MIB1 Bolero/Amundsen. I have installed it without issues. Users previously contacted me: check your PMs. Others just contact me for the deta
Hi - can anyone send me a link for the latest firmware?
Pic attached.
Thank you in advance!
Pic attached.
How about 0490 via PM
Thank you Varooom, I'd be very grateful!!
Bingo!  And as if by magic all my crackling sound issues have been cured.  Touch seems a bit more responsive too!!  Thank you so much.
Hi guys, can you help me with the download link for newest SW version for MIB Amundsen? now i have 0245. Thank you.
Can you press and hold down your Menu/Setup button for about ten seconds to enter the engineering menu, you are looking for "Software Train"
This might be what you have now (MIB2 not a MIB1 where you posted)
MST2_EU_SK_ZR_P0245T
Available update if you are MIB2
MST2_EU_SK_ZR_P0253T
Post back what you have in the screen
@SuperLaur I will PM you MIB2 firmware, grab your private message in next 5 minutes.
Thank you so much. I have another question if you are kind to help. I have the original SD card from Skoda with 16 Gb, i downloaded from updateportal the latest maps for my region and total is 9gb, but when i'm trying to copy to the formated SD card it says that is not enough space, what i'm doing wrong? Thank you again.
Try to copy the existing content to Desktop folder called "Backup Map" and then delete the content of the card (not format)
Make sure you do this task on PC, not a MAC.
Then try again to copy maps to the SD Card.
If issues, please post back.
Link to ECE 7 Map, and the correct filename, can you check it matches your file downloaded for map?
https://vw-maps-cdn.lighthouselabs.eu/vw-maps/DiscoverMedia2_EU-DL4_2010_V17.7z
Edited by varooom
Additional Information
Ok, thank you for all the info, i will try these and then i will come back with news. Have a great day!
P.S. I downloaded the SW!
I just updated the post above, link to the map section, and direct link for ECE #7, if you can check this is correct map file you have in your downloads?
Wow, true, this is different from what i downloaded from Skoda. Do you know this map works on a MIB1 Columbus?
You have a MIB2 Amundsen, definitely not a MIB1
Your part number on the left, as seen in your image.
Edited by varooom
Yes i know that i asked you for a MIB2 Amundsen, but i have also a O3 2014 with MIB1 Columbus, i have the latest SW, but not the latest maps :)
Gotcha, busy times here.
Try this thread for all things Columbus
Thank you so much for patience and your time to answer, i really appreciate this.
I don't have a MIB1 Columbus, so not sure if those maps will work.
I think you can use any SD Card for the Columbus maps, but could be wrong.
Either way best of luck.
I will let you know if it works, or not :)) hope it will work, at least for firmware upgrade. Cheers!
Hi can somone please direct me the best place for the update. Psa the picture of my current version.
Hold down your Menu/Setup button for about 10 seconds to locate Software Train.
Update should be available to 0490,
Boys, if anyone has a 0490 link to download? Currently i am ln 0421 and feels a bit slow.
thank you in advance
5e0035874a
hardware 040
5e0035874a
hardware 040
Update sent via private message
Hi! I've been looking for a 0490 update for ages. Is there any chance I could get it via PM? Thanks!
