Amunsen MIB1 Firmware
Hi guys, please can someone send me where to download 0490 version for my Amundsen mib1, Octavia mk3. Thank you
[email protected]
  • Replies 982
  • Views 216.1k
  • I have updated my Amundsen from 0435 to a newer version which can be found on the net. I don't want to share the link here to avoid deletion but I will kindly PM it together with the instructions.
  • If you have instructions they'd be appreciated
  • Guys,   From now on a newer firmware is available for MIB1 Bolero/Amundsen. I have installed it without issues. Users previously contacted me: check your PMs. Others just contact me for the deta
Please make a picture of your software train to verify.  Hold your menu/setup button down for 10 seconds to find out.
3 minutes ago, varooom said:
Pro ověření udělejte obrázek svého softwarového vlaku. Chcete-li to zjistit, podržte tlačítko nabídky/nastavení po dobu 10 sekund.
20 minutes ago, Samuraj88 said:
I shall be able to send file in 20 minutes roughly.  This is also your firmware update button you need to press.
Soubor budu schopen odeslat zhruba za 20 minut. Toto je také tlačítko aktualizace firmwaru, které musíte stisknout.
Ok, perfect, thank you
Thanks to varooom for firmware actualization.
Spoiler
Hello!
Can anyone help me with the firmware update?
My email adress is   [email protected]
Thank you!65275676-8512-4115-A131-3A41EC9D4E98.thumb.jpeg.f8981b53bfdef50d1e233148b663b8d6.jpeg
My email: [email protected]
Thank you very much!
@alexandrupt @bakomisi
Also email is no good, as file is several gigabyte's.
20 minutes ago, alexandrupt said:
PM on it's way
10 minutes ago, bakomisi said:
You have latest
Hello!
My email adress is:  [email protected]
Thank you very much
2 hours ago, trozzz1k said:
Hello!
Thank you very much
I can send you link to 0490 version in PM in a few minutes
Edited by varooom
Hello! Can anyone help me with the firmware update of my Amundsen MIB1 from a Skoda Octavia Scout 2015?
I attached a photo of my actual firmware.
Thank you in advance for help!
You can update to 0490 version, can send PM in a few minutes.
Yeah, i know this is the last version. Thank you!
I just updated the firmware from 0435 to 0490 (thak you, varooom ). I wanted to do this update in order to fix some issues about the quality of audio. I read in this forum for some audio improvements with the 0490 firmware.
So, all process went straight forward, took about 35 min, engine on.  After the update was installed, i checked and erase all errors  with VCDS.
First impression: everythig is the same as before, except the sound: Lower tones are more consistent, medium tone are the same but the big problem is: High frequency tones are too low. I think like 30% less than in 0435 firmware. At least this is what i felt from the moment i turned on music. Sometimes is like i don’t hear some sounds.
I decided to stay with 0490 for a while but unfortunately for me this lack of treble sounds is a no go.
It is possible to downgrade to 0435 ? Thank you.
I have 0465 and 0490, not sure if it accepts downgrade, but I don't have 0435 to roll back that far.
Try to adjust as much as possible, if not we shall have to try these alternatives.
After couple of days, after listening my music in car, i came to the conclusion that audio quality is the same as before update. So, i’ll stay with 0490 firmware. Ne need to downgrade.
There's no sound coming from my radio/by etc after a restart. Usually at first start in the morning there is no problem. It seems a firmware update could do the trick. Thanks in advance.  A picture from my system:
S00.1000.17.99
release = "MHIG_EU_SK_K1552"
MUVersion = "0411"
There is this update available, so will send you a PM with link
On 08/02/2020 at 09:29, BATVANVRS said:
Anyone that needs the firmware then PM me your email address.
Will the software you have work with mstd_eu_sk_p3420 thanks
MSTD_EU_SK_P6230
0490 is available if he doesn't respond to you.
Hi guys,
Would anyone be so kind and send me link to newest software for my Amundsen Mib1?
(email removed)
Thank you in advance :)
Edited by john999boy
Personal details removed
