Resetting Service Alert Indecator
hi guys,
do any one know how to reset it ????
You will need either a 1552 unit or VAG-COM to do this. Failing that, take it to your dealer and they will do it for you.
i think you will find if you read your owners manual it tells you how to do this !
sorry guys
u dont need any thing to rest it ... u can do it by a small trick in the dask board, and i dont want the dealer to do it becuase i can do the oil change out side why 1/4 of the price :D :cheers: :p
once the dealer made it infront of me ... but i forgot how exactly ... its the signle aram and the reset milage botton
if u got any information guys please tell
Done it myself when the dealer failed to do it.
Definalty covered in the manual but too arcane for me to remember.
Yep, can be done. I cant remember what page of the english owners manual it's on.
Found it in the manual :D :D :cheers: :D :D
for ppl needs it its
1- switch off ignition and press the reset knob for the trip counter and hold
2- switch the ignition and release the reset knob , one of the service event apears in the display
3- when the desired service event is displayd turn the knob for setting the digital clock to the right "serivce --- " apears in the display
4- switch off the ignition the service event is now reset.
Which other service events are there?
Rob.
See I told you I was arcane
In the RS you have to run widdershins around the car as well :)
:confused:
one thing i didnt write it was in the manual .... they says ..... dont play with it ... or you may cusea fualt in the car
