Front Door Rivets....
On here somewhere, I should think. Item 17?
Edited by Wino
These three are what hold the door card to the door, the three Philips screws similar thread to 13mm bolts I belive.
These three are what hold the window motor to the carrier by the three black lugs sticking out, 3 torx screws with sort of wood screw threads.
Cheers, least I knw whats what now. Been scratching my head about it. Realised door card still has to go on. Lol
Any idea on the size of the torx screws?
Sent from my SM-G920F using Tapatalk
They are a strange size so will be best going to the dealers and getting the right ones.
Window motor screws are part number N01021226
Size M6x12
Edited by TMB
I didnt check this earlier as was struggling for the screws. Rang up my local skoda and they didn't have a clue.
Told me they would all come with the regulatory...hmm.
Nyways look what I finally did
Can't believe how easy it was in the end.
I found some screws & nuts about and did a cowboy job.
  • 4 years later...
Hi does anyone know what length of the M10 bolts are thanks in advance
14mm.
Part number N 904 911 01
A very good idea is to install rivnuts and bolts instead of the rivets. Makes life easier when dealing with broken window holders, door lock, damaged elec wires in the rubber below...i experienced it all
Just drill the rivets out if you need to, they're cheap and easy to replace if you need to get in there again. Using bolts is much more expensive, a rivnut tool costs far more than a plain riveter and the rivnuts cost more than rivets, it doesn't make any sense.
Just depends if you can get the rivnuts flush, if they aren't it's going to leak.
If you have at hand kind of rivet gun which is able to use this big rivets than it is easy.
If not, you can install rivnuts with 2 spanners, a bolt and few nuts (you can find online how ti do it).
I dont have any leaks, used it on 3 doors.
Thank you for your help everyone I will be using rivnuts and used them before on another car few years ago and i used the method pavinjo mentioned
Can you tell me what size you used please
Sorry, i checked but no any spare to measure. Should be about 30-40mm, sorry not to be able to tell you precisely
No problem pavinjo. Im just going to get mixed ones and see which fit I will be making a guide so other people can follow as not much on this subject
Did you ever make a guide for how to use rivnuts on the door carrier? Want to get my door apart this weekend but struggling to get suitable rivets in time
Sorry never had time but this what I bought link at the bottom.
just go on YouTube to show you how you remove door card.
once off drill old rivets out
install rivnuts and get the same size bolts for the rivnuts you installed
Done.
I say it take you 30 mins a door to do
https://www.ebay.co.uk/itm/Rivet-Nut-Gun-Hand-Blind-Riveter-60-150PC-Mandrel-Repair-Tool-Set-Metric-M3-M12-/203519533377?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l6249&mkrid=710-127635-2958-0
Done.
Great stuff thanks. Now its just to get the door open in the first place in order to figure out whats wrong!
I never had that problem do can't help but Check on YouTube plenty of videos showing how to open them as its a common problem
Just got the door open by taking the central locking fuse out and putting it back in again!
Must be a wiring problem
