Superb II Detachable Tow Bar recommendations
56 minutes ago, leszek_c said:
Hi folks,
I bought a kit from PF Jones. Westfalia tow bar with a dedicated wiring kit FF29220508PF. My car Skoda superb estate 2014 2.0TDI. . I installed the towbar, routed the electric harness along the car, and stopped there. The problem is that I can't fit the terminals into the fuse box. Do you have to use force to insert them or are they just not right. The terminals go halfway and I still can't push them in, they can be easily removed.
Thank you kindly for answers.
You have to unlock the fuse box. The pink part at the back slides down and allows the terminals to be inserted.
  • Replies 158
  • Views 36.4k
  • Perhaps share what the issue was, may help future posters.
  • As far as I am aware Westfalia make VAG cars towbars, I know they did for my MK1 Superb and also my Octavia before that, I found a Westfalia towbar on the net for a lot less than a Skoda branded Westf
  • Just for the record the official Skoda bar for the superb 2 is made by Prof Svar, it's not a Westfalia.
You need to take the fuse box off its mountings, open it up and insert these leads from the back to the relevant fuse positions:
There is a very good You Tube video by 'Lutz', which shows a complete tow bar install with wiring to the fuse box, which I recommend you check out. Sounds like you have done all of the hard work already!
I have not tried to slides down the pink part. I will try this tomorrow morning.
Thank you very much chimaera.
I took the fuse off as you said and actually i was following that video as well before. And the guy in 22.22 minute was strugling to insert the terminals in.
But as a chimaera mention there is a a pink part to slide down to unlock the fuse box and allows the terminals to be inserted which is not mentioned on the video.
I will do it tomorrow morning and I will let you know.
Thank you guys for reply. I appreciate your help.
Leszek
Leszek
Hi guys,
Job done. There is a littile latch to be open and then you can slide down the pink part of the fuse box. And then without problem I have inserted the terminals. Finally job completed.
Thank you "chimaera" and  "smart pro" for your help.
I've done adaptation and everything looks work fine. But i haven't got the trailer yet to test it. :) looking for a caravan  to buy soon.
On 18/11/2022 at 22:53, leszek_c said:
Hi guys,
But exactly that was explained in instruction no 32 of the instructions that you added to your post? How did you miss that?
(Since it was indicated so clearly in the instructions that you yourself provided, it did not occur to me that you did not do this)
Edited by andrehj
Indeed. What a fool I am. No further comment. :)
  • 2 years later...
Apologies for ressurecting an older thread, but it's extremely useful.
I'm searching for options to fit a detachable towbar to my Superb MkII estate. I'd like to go OEM or as close as possible and have the additional coded towing options as well.
There seem to be plenty of 2nd hand options for the Octavia, but would an Octavia wiring loom fit a Superb without modification?
Unlikely. Even if the wiring pinouts matched up exactly (and there's no guarantee of that), the Superb is much longer and the wiring from an Octavia is unlikely to reach far enough down the length of a Superb for it to work. The wiring runs from the fuse panel on the driver's side of the dash all the way to the rear of the boot.
